Kahuna
Moderatoring
As I consider displacing my MX20 with the new HX EFIS screen, Im stuck on one final piece of functionality. I cant figure out how or where to get airspace info on the GRT. Cant figure out what airspace is ahead of me. Do I have restricted ahead and below? What the ceiling on that class B ahead and what alt can I climb to before I hit it? Is that a MOA over there? Whats the freq for the controlling agency? And on and On and On.
These simple questions I cant seem to answer on my GRT Horizon 1 HS screen but is mission critical to my everyday flying. Am I missing something? How are the rest of you getting this on your GRT moving map? Every other moving map I own tells me this information. My old portables with limited functionality have this function easily available. Its required stuff to keep alive, safe, and out of FAA jail.
Airspace ceilings are intemittent and Im unable to determine the algorythm for their showing up. Most of the time they dont. All the time I want em.
While its true it highlights a space if Im going to go through a space, thats only if Im in it, or at the altitude it is. Thats less than half the battle and does not take into consideration what I want to do, only what Im doing.
I would expect to be able to select airspace just like I select an airport. Push knob, turn and highlight, select details, and find out everything I ever wanted to know about the space.
Who can help?
Note: Ordered 1 HX at SnF for June delivery. Still waiting. Carlos saying October now. Glad I dont need it. But I will replace my 1 HS regardless if and when the HX ships. Weather or not I get 2 and dump the MX20 is now my issue.
Who can help?
