Steve Sampson
I have a PM3000 and am very disappointed. It is by far the most frustrating bit of kit on my RV4. I bought it because I was told it was excellent but that has not turned out to be the case. To be fair it may of course be the harness.
First off it has been exchanged by PS Engineering for another unit, but it behaves the same. So it is either that is the way the units are, (second rate) or the installation.
What I have done to diagnose the problem is this.
1. Turned everything off on the aircraft so nothing is radiating.
2. Plugged the headset directly to the radio at the diagnostic jacks that PS recommend, and listened to the radio. Between transmissions it is dead quiet.
Turned the radio off.
3. Moved the headset to the intercom jacks (pilot or P2 are the same). Background white noise. Not loud, but enough to irritate, especially after a while.
4. Moved the squelch through its full range. Nothing changes
5. Moved the volume through its full range. Nothing changes except perhaps right at the top end there is a very slight increase. (From this I deduced that the noise is not coming in through the microphone circuit since then it would react to the volume control.)
6. Moved the pilot isolation switch - nothing changes.
7. In desperation I have also pulled the plug from the intercom and put a meter on the pins that lead to the headset earphones. Nothing is shorted to ground.
8. At this point I have pretty much run out of ideas as to where the noise is coming from. The harness is made with shielded cable of course.
Can any audio experts tell me what my next step should be?
Apart from this background white noise it works in all other ways.
