08-11-2008, 01:32 PM
<<It turns out that in the RV-8, the pedals are designed in such a way that any pressure on the pedal at all -- even just to use rudder -- exerts a force on the brake cylinder. This is true for every 8 built to plans.>>
Totally true, and if you have big feet it is worse. I've done the "rod mod" before. I seem to recall a more elaborate pedal mod also. Anyone have pics? I'm going to do something with the new bird's pedals even if I have to weld up a new assembly. The catch to the rod mod is that it steals 3/4" of legroom, and concentrates pressure across your foot if you wear soft shoes.
Dan
Dan Horton
RV-8 QB - Alabama
Barrett IO-390
08-11-2008, 01:38 PM
Brake Fire
When I installed my brakes from Vans, I modified them by replacing the standard Nitrile O-rings with Viton (sometimes refered to as Flourocarbon) O-rings of the same size, the Viton has an upper temperature limit about 100-125 degrees F higher than Nitrile, however it is only good down to about -15 degrees F (I'm not too worried about that in Calif.). The other modification i intend to make is to use either the Mil-H 83282 hydraulic fluid or Mobile one Synthetic automatic transmission fluid for an increased flash point temperature. (the temperature at which the fluid will burn in an open container.) If you compare the specification data between the Mobile One synthetic Automatic transmission fluid and the Mil-H 83282 hydraulic fluid, you will find that they are very similar and the I have found that the Mobile one trans fluid is more readily available.
I hav found the best source for O-rings (if you don't need tracability or special compounds) to be Mc Master Carr.
Mike Warfel
RV-8
Finishing
Reason: added source info
08-11-2008, 01:57 PM
I can stay off the brakes by using the sides of the peddle "frames", and I have # 12 EEE's. It's a little awkward at first, but it beats the heck out of replacing o-rings, or running for the fire extinguisher.
08-11-2008, 02:06 PM
Part of the problem is people mount their rudder bars completely vertical. Ideally they should be sloped away from you a bit so your toes aren't hitting the brakes when you're working the rudder. This is part of the problem with people dragging brakes. If you shorten the rudder cable 'links' and mount the rudder bars a little more forward there's no problem. I have had no problems so far in 160 hours and my pads look like they can go another 160 or more. I also installed auxiliary return springs on the master cylinders which I feel helps with brake life.
Jamie D. Painter
Suwanee, GA | Home Base: KLZU
RV-7A First Flight: 7/27/2007 | 330 hours
Slow-Build | Tip-up | Superior XP-360 (injected) | Hartzell BA C/S | Dynon EFIS+EMS | Garmin 496 | Digiflight II AP
08-11-2008, 02:44 PM
VAF Moderator / Line Boy
Dan
Here is a picture of the "pedal extension" mod (scroll down to my first panel picture, and you can see the pedal extensions). It is pretty easy to do, and gaurentees that you are taking pressure OFF the brakes, as long as you have your toes low on the pedals. But....it doesn't fit everyone's ankle geometry, so I don't consider it a universal solution. I like it, but have flown -8's without it as well.
It's important to remember that the -8 pedals are different from those on the side-by-sides (and the -4's, and the -3's...), so what works for them might be different than what works on an -8.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie" - 1100+ Hours! TMX-0360 (180 HP), Hartzell Blended Airfoil, GRT EFIS panel
RV-6 (By Marriage)
RV-3B - Fuselage out of the jig!
VAF #35
EAA Tech Counselor/Flight Advisor
Polly Ranch Airpark (7XS0)
08-11-2008, 06:28 PM
burning brakes
during my search for a airplane (rv) i came across an article about brake fires and i believe it was on this site, anyway the solution was to use automotive dot fluid , it is non-flamable-- but here is the critical part-- you must use o-rings compatible with the dot fluid. i will try to find the contact info for this guy as he had to buy a pretty large quantity. good luck
08-11-2008, 06:37 PM
brake fluid
There is a lot of info in the archives on the topic of brake fluid, brake modification, and brake fires:
http://www.vansairforce.com/communit...ighlight=brake
Based upon the info here I replaced the seals in my 8a project with those compatible with automotive brake fluid and plan to use that.
Tony Johnson
RV8A "Badboy" N12TJ res
Orlando
08-11-2008, 06:58 PM
Please send pictures.
08-11-2008, 09:11 PM
Hi Mike - did you change the O-rings in the master cylinders also? I'm planning on running the "other" milspec fluid and am thinking of changing O-rings. Is the Viton only for heat or for fluid compatibility?
I've flown a C150 at -15F, so that might actually be a problem... BRRRRR
dave
Dave Gribble VAF #232
Building RV-9A N149DG (slider, O-320-E2A, Dual AFS-3500)
Flying the Mighty Skipper N3726B
Cedar Rapids IA
Canopy bonded - starting side skirts
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
08-11-2008, 10:06 PM
Brake fire
Hi Rich,
Thanks for your reply. I would greatly appreciate you pictures of your brake pedal modification. I feel that this is definitely a part of my problem.
Many thanks for your reply.
Jim
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
