Nuff said
What you said - And, like I said that is silly. Lots of people have "lost the fan" in Lancairs and have been fine.
Most people agree with me and can put 1 + 1 together, understanding
LOWER STALL = A BETTER CHANCE. Clean stall speeds of Lancairs like the IV are very high, much higher than an RV. If the the square of speed equals energy does not make sense to you, than so be it.
As far as sink rate, again Cafe numbers are based on partial power and gear up. Those Lancairs with 3 and 4 blade props and gear down will fall out of the sky at eye watering rates, just a fact. It's a matter of wing loading, drag and aspect ratio, no magic, just basic aerodynamics. Even MT has offered feathering props retrofits to current 3 and 4-blade users on single engine kit planes. Why? because of the scary characteristic of massive flat disk drag in engine out conditions. People have noticed. Apples and apples and read the cafe reports first. Understand what you are quoting.
CAFE SINK NUMBERS only say the Lancair has less drag with gear up (no kidding) and the same or better lift at a higher airspeed, aka L/D is proportional to glide ratio. YOU ARE DISCOUNTING THE FWD SPEED which is much higher. You have to DEAL WITH THAT SPEED when you hit the fence, ditch, street sign or tree. Speed kills. Now if you have the skill to transition to full flaps and hit your aim point of intended landing, dead stick just above stall, YEA! LAST BUT NOT LEAST - the Lancair has flaps BECAUSE IT NEEDS THEM. The clean stall speed is VERY much HIGHER than dirty. An RV does not care, flaps up or down, it's only 3 to 5 mph difference in stall speed.
You say OK feather prop, keep the gear-up and get the flaps down? Well fine, that would be great, if it's not right after take-off. NOW THE PILOT HAS A SECOND OR TWO TO EVAL, DECIDE AND ACT BY bringing up the GEAR, FEATHERING PROP AND GETTING THE FLAPS OUT (under stress). A subtle point I made before,
a Lancair puts WAY more onto the pilots skill, training, currency and decision making than an RV. i.e. ,
Its easier to lose control of a Lancair, thus making the RV safer in this human factors aspect as well. (why do they make trainers simple?)
Also with the gear down on most retract glass airplanes (and I have helped build some), they just break off in and accident (some times opening up the wing tank), so they don't absorb much energy. On the other hand solid mount metal spring gear's absorb more energy, bend, yield and don't depart the airframe, at least for survivable landing accidents. That is all. Ductility.....gee how can I say it so you understand, with out you calling my comments silly?
The Air Trans ref was to make a point, pro Lancair BTW, even a JET can be safely dead stick ed to a safe landing.
I can't teach fracture mechanics or crash worthiness desgin principles to you in a short post. However I stand by my silly opinion the lower stall speed, fixed gear, metal airframe RV is safer in a CONTROLLED crash than a Lancair IV. We agree to disagree obviously.
ALSO
Obviously all bets are off in ANY AIRPLANE, if you lose control. So losing control is moot, irrelevant, silly and off the table. Lose control and die. Your chance of survival if you stall and spin goes to Nil. As I said before the body can tolerate tremendous g's in the fwd direction, but server injury occurs with a faction of the g's in the vertical direction. Stall spin accidents produce tremendious vertical loads.
Focus, on what I'm saying please! This has to do with the materials ability to absorb energy......metal is better. It has nothing to do with design or whose plane is better, bigger, faster, cost more or whatever.
Obviously in Milts case his composite plane was very strong and well designed. He feels it saved his life. I believe him, but in general composites are not great in a crash, because they fracture and do not yield. This characteristic can be a good thing or bad, depending on the material and how the designers use the material. Milts plane was apparently very strong and resisted breaking up, excellent, a good thing. It well may be as Milt said, the same accident in a metal airplane (F1) would have caused injury, I guess due to excess deformation and cockpit being compromised, in his opinion. I say MAY HAVE since Milt is making conjecture; unless we crash a F1 in the same manner; we don't know for sure. Forces during a crash are VERY complex. Sorry I have a degree in engineering. I deal with facts, but appreciate peoples opinions. Milt made a good point. I agree, composite rigidity and ability to NOT deflect
can be goodness, but it can be a negative.
Even when I agree with composite plane enthusiast, it's ignored and all that's seen is RED, from the slightest criticism. Out of college I was a structural engineer for Boeing, including metal and composite structures. I don't know everything, but I do know about aerospace structures and engineering materials in failure modes. Feel free to disagree, but please be polite and debate facts not personal issues.
