Old 01-10-2009, 05:33 PM
RV6_flyer's Avatar
Originally Posted by Sheldon View Post
Anyone know the (average) cost of inspection/replace needed parts in Slick Mags?
Or: cost compairsion between inspecting/repairing vs. buying new and just remove & replace?
Are the new Slicks from the factory void of the SB now?
Also, has anyone done their own inspection & repairs? Or is this something left to the 'professional'??
I'm at the 500 hour mark on mine and am wondering what to do...
Sheldon
I paid fiveteen cents for the cam and about $16 for the brush from Aircraft Spruce.
I did the work myself. I opened the one I have up that needed the inspection by serial number and it will be getting the new brush at the next inspection in the next week or two.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-10-2009, 06:14 PM
Sheldon's Avatar
Sheldon Sheldon is offline
Thanks guys... I've built radios, rebuilt engines and repaired clocks..(Oh..built my plane)...so I guess I can do my own inspection/repair... BUT thanks for the info.. I just needed the reinsurance from the RV comunity...
Will look into the tools and parts to order and jump in... Will let you know what I find and find out...
Sheldon
Old 01-10-2009, 07:08 PM
bhester's Avatar
bhester bhester is offline
Default Slick mag repair pictures
I just did mine a few days ago. It had 260 hrs. on it. I took some pictures maybe they will help.
Watch the slide show.
http://picasaweb.google.com/bobbyhes...ckMagTeardown#
I am currently working on a powerpoint presentation for an EAA chapter meeting.
Things you'll need to have on hand:
Unison L-1363C Manual
Unison T118 Timing Pin - http://www.aircraftspruce.com/ (search T118) $4.80
Unison T150 E-Gap Tool - http://www.aircraftspruce.com/ (search T150) $12.90
Torx T20 Screwdriver (bit with a socket to fit it and a small ratchet was helpful)
Hammer
Timing Buzz Box - http://www.magnetotimer.com/
Mechanics Toolbox CD - http://www.aircraftspruce.com/ Helpful directions
Replacement Parts - http://www.airpartshopping.com/ This is were I bought FAA approved aftermarket parts for slick mags.
AM3215 Carbon Brush $4.99
AM3611 Cam $0.46
A13081 Point Kit (didn't use now but wanted to have it on hand) $25.01
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-11-2009, 08:31 AM
Sheldon's Avatar
Thanks Bobby...Your slide show worked for me... I think I can do this..
Is the tool # T-100? The only 'special' tool needed?
Thanks, Sheldon
Old 01-11-2009, 10:37 AM
Sheldon's Avatar
buy the cheap little tools from ACS,
Paul... just what are these tools you refered to from ACS.. have a p/n ?
Sheldon
Old 01-11-2009, 06:57 PM
bhester's Avatar
Default What you'll need to work on your mag
Hammer
AM3611 Cam $0.46
I think this is the cam lube that you need also (I didn't have it) but check with them to make sure
LUBE CONTACT
Item #: A13081-8 $0.74
Old 01-11-2009, 07:05 PM
rocketbob's Avatar
rocketbob rocketbob is offline
Thanks, Sheldon
You only need the T-100 toolkit if you have to pull the rotor out to replace the bearings. Otherwise you just need the e-gap tool and a timing pin.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 01-11-2009, 08:01 PM
RV6_flyer's Avatar
You can make the timing pin. Years ago in A&P school, we used a short piece of brazing rod. I still have it and it works as good as the Unison alignment pin.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Old 01-11-2009, 08:09 PM
Mel's Avatar
Mel Mel is offline
Default You don't need no stinkin' timing pin.
I use a pop rivet mandrel. I slipped a piece of plastic tubing over the rivet for a handle. Been working for 35 years.
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School RV-12 Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-11-2009, 09:20 PM
Sam Buchanan's Avatar
been here awhile
Most A&P's probably have a box-full of timing pins since one comes with each new mag. Just ask.
Sam Buchanan
RV-6
Fokker D.VII replica
