06-18-2008, 02:47 PM
Best tools for final canopy trims?
I'm to the point of my forward canopy work where I'm ready to make the final trims. I'm talking less than 1/8" at the most, with most of what's left to come off being less than 1/32" or so. These trims are not going to happen with the cut off wheel, and I'm wondering if there is a certain tool (file, sandpaper, etc.) that others have used to gently bring the edge to the final trim line. The really narrow parts will be sanded with a sanding block, but can I safely file some of the thicker areas?
Chad Jensen, VAF-755
RV-7|Tip up|360|VFR Lightweight
N755CB
RV-7 Build Log
06-18-2008, 02:58 PM
VAF Moderator / Line Boy
I found that a hand-held belt sander was good at taking off significant amounts in a very controlled manner Chad.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie" - 1100+ Hours! TMX-0360 (180 HP), Hartzell Blended Airfoil, GRT EFIS panel
RV-6 (By Marriage)
RV-3B - Fuselage out of the jig!
VAF #35
EAA Tech Counselor/Flight Advisor
Polly Ranch Airpark (7XS0)
06-18-2008, 02:59 PM
I got pretty close with a belt sander. Then I used the two-handed notched scraper tool I purchased from Avery for final edge finishing. The Avery tool works like a draw-knife.
Steve
06-18-2008, 04:14 PM
I liked a 1.5" sanding drum (Lowes, HD, etc) in a die grinder. Light pressure, long even strokes. Coarse grit takes material off very quickly, so go easy or use fine grit (which can still go pretty quickly). Always work against the rotation of the drum, ie, so that the "dust" is pushed forward.
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
06-18-2008, 05:03 PM
Angle die grinder
I liked a 2 inch disk on an angle die grinder.
Follow up with a rubber block sander with 100 grit in steps down to 600 grit of wet/dry paper used wet.
This leaves a nice polished edge.... use a softer block for the last few grits, and the edges will be nicely knocked off.
Gil Alexander
RV-6A VSB (Very Slow Build)
Grumman Tiger N12GA - flying
06-18-2008, 07:24 PM
I used an orbital sander with progressively finer grit sand paper. I finished up by hand with a sanding block and used wet "wet & dry" for a final polish.
Jim Sharkey
RV6 - Finishing Up
06-18-2008, 08:11 PM
Jim Sharkey
RV6 - Finishing Up
I agree with using a small palm sander, random orbital or otherwise. Belt sanders work, but they are really better used with two hands and can get out of control real quick. (I've got lots of experience with messed up furniture I've built to prove it  , plus they take off quite a bit of material quickly, even with a fine grit.) I used 80 grit, then 150grit, then 200 grit on my orbital then finished up by hand with 200 grit again then 400 grit to finish. Good luck, sounds like the canopy is almost history for you! Defintely a good feeling.
Steve M.
Ellensburg WA
RV-9
FWF wiring and plumbing
06-18-2008, 08:21 PM
canopy trim
A beltsander did a great job for me.
06-18-2008, 09:02 PM
Thanks for all the replies/ideas guys! I'm gonna use a combination of the suggestions, and have already gone out and bought sandpaper in increments...all the way to 2500!!
It's all masked off as of tonight, and I'll be ready to start the sanding this weekend.
I still have the rear glass to do, but getting to this point on the front has been rewarding, but quite the process!
N755CB
RV-7 Build Log
06-18-2008, 09:08 PM
It was suggested to me to use Perma Grit blocks when I started doing fiberglass work. I found that they also did a great job at plexi work.
You wana have your RV FLYIN by when? Lately I'm trying to decide whether to paint the wings first or just permanently re-mount them and paint later. Give me a few months I'll decide.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
