Old 05-26-2008, 07:35 AM
Geico266's Avatar
Geico266 Geico266 is offline
Default Adding Cowling Louvers / RV-10
I need to add a second set of louvers to the bottom of my coweling. What are you guys using for additional louvers? Are they coming from Vans or are they after market? I searched, but got caught up in the "tunnel cooling" threads and could not find it.
Thanks for any help / suggestions.
RV-8 : Just Sold
RV-10 : In the hangar
RV-12 : Built and sold!
RV-44 : 4 place helicopter on order.
Old 05-26-2008, 12:13 PM
Take a look at this thread.
http://www.vansairforce.com/communit...?t=7621&page=4
Old 05-26-2008, 02:04 PM
db1yg's Avatar
db1yg db1yg is offline
Hi Larry,
Try the following link:
http://www.aviationtechproducts.com/...cessories.html
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 05-26-2008, 04:15 PM
Geico266's Avatar
Thanks Mike, Dave.
I ordered the aftermarket louvers and will get them installed in the coweling.
RV-8 : Just Sold
Old 05-26-2008, 04:17 PM
bcondrey bcondrey is offline
Larry,
I've got a pair from Aviation Tech Products that I didn't use/need. Yours if you want them - I'm just up the road in Omaha.
Bob
Old 05-26-2008, 04:34 PM
Geico266's Avatar
Originally Posted by bcondrey View Post
Larry,
Bob
Sweet! Man I love this web site!
Bob, They have 2 sizes, which one do you have?
RV-8 : Just Sold
Old 05-28-2008, 06:34 AM
Geico266's Avatar
A special thanks to Bob C.
I drove ( weathered in ) to pick up the louvers and check out Bob's newly flying RV-10. I can report I got to see both a fine example of an RV, and a fine example of the quality of people that is VAF.
Thanks Bob, I owe you a cold one.
RV-8 : Just Sold
Old 05-29-2008, 07:40 AM
Jim & Julie Wade Jim & Julie Wade is offline
My question is, why add more louvers??? I have almost 200 hours on my RV-10 and I never see over 190 cht in a climb or over 175 cruise and I cruise 75% all the time leaned to peak. (which if you check the lycoming manual is OK) I did see high temps before breakin, but not after. I am monitoring all 6 cyl egt and cht. I also run gami's. Just wanted to put my 2cents worth in. A lot of builders really worry about trivial things!!! Van has a great plane, doesn't need much improvement. A little more HP would be nice though.
Jim
Old 05-29-2008, 12:45 PM
Geico266's Avatar
Jim, Trivial? I'm not sure what your definition of think trivial is, but vapor locking and loosing engine power from a heat soaked mechanical fuel pump is not "trivial" in my book.
RV-8 : Just Sold
Old 05-30-2008, 06:30 AM
I have a temp probe in my engine compartment. The most I ever see is in the 180's climb, in cruise around 150's. If everything is baffled tight and properly installed (I used factory firewall farward kit) I just can't see why the heat problems. Not looking to cause a ****storm, just letting you know my experience.
Jim
