I have just about run out of ideas. So I thought there might be a opinion or two here.
first its a -7 ,Lyc O-360 180hp been flying for several years and I have always had to baby it during the summer to keep the CHTs from going out the roof.
Yep. I have checked the calibration on the probes.
This winter, I decided to make a effort to solve it.
I had a few nonstandard RV items. It is now plain vanilla van's RV-7. I replaced the Skydynamics 4 into 1 because I thought it might be distupting the exit air.
I had a not standard intake air box because of the exhaust header shape. have not put the std van's air box on with Vetterman's crossover.
I have a EI on the right and mag on the left. I checked timing on both a couple weeks ago.
I put ramps on both #1 and # 2 cylinders to divert the airflow rearward. I don't have leaks around the baffling.
The between cylinder baffels are in place.
Both back cylinders CHTs are over 400 on any climbout. If its heat soaked in the ramp, takeoff will go over 500 cht. That's just too hot.
the front cylinders are on the warm side too, but they lag along behind the rears.
the egts all run 1300 to 1400, which seems fine.
oil temp will climb to over 200 as the chts heat up.
Last week, I taped a duck tail on the cowl exit to attempt more of a suction at the exit.
I even drained a tank and put 100LL rather than the car gas I normally run this past Saturday.
nothing I have done has changed it at all.
I think my next move to to attempt a manometer on the upper and lower pressure chambers in the cowl.
cary
cary
