zkvii
Hi
We are continuing with refinement of our cowl air inlets after getting the bulk of the cooling issues sorted. I now have instrumentation for upper (plenum in our case) vs lower exit pressures and have got graphs for the various air speeds.
I've tried three different inlets (sharp, rough foam hemisphere and profiled Kuchemann shapes). A major part of my problem now is not knowing what a 'standard' VANs soft baffle configuration is to start with (it probably doesn't matter that much about TW vs Nose or specific model 6-9). Has anyone done this measurement at all? Normally it would be via an ASI and two tubes with picollo tubes. (anybody keen to? )
As an example of some of the data I've been working with - this was the Kuchemann profiles on a short run yesterday.
Thanks for any other data,
