alpinelakespilot2000
While attaching the z-brackets to my tank with the closed-end pop rivets, I ran into a problem I've never had before. My rivet puller pulled one of the pop rivets but chopped the mandrel off about 0.5" above the head rather than flush with the head. I'm not sure if it was because it was a crummy/cheap puller or whether I did something wrong, or because perhaps the mandrel hadn't been scored where it is supposed to break. Now there is not enough mandrel for the rivet puller to grap onto to cut it where it should be cut.
Anybody know why this happens? What do I do with it now? Just cut off the remaining mandrel with some wire cutters?
Steve
Steve
