Hey out there I need some ideas. I bought a used 0540 260hp. I did nothing to the engine but install it. It started and ran fine and the tempatures were ok. The trouble was the left mag was dropping off about 250 rpm and I was not getting ful power. I put the timing up to normal 25 before TDC and the temps went up out of limits. I could only fly at 12 inches of MAP and nurse it back home. The lower baffling under the cylinders was missing when I bought the engine so I bought some and installed it. Now I can fly at 15.5 MAP to keep it with in limits. Remember with out the lower baffling and the timing retarded it would stay in limits and around 375 cyl head temp in cruise. Now with the timing set right and the new baffling installed it is out of limits three minutes after take off. The number one cyl is very unmanageable. I used a baffling kit from VANS and no air is escaping around it. Has anyone else had these problems with the RV10.
