Load meter v Battery meter
Here is you pic with some notes: (click once or twice to enlarge)
(edit fixed boo boo)
First I would recommend a LOAD (amp) meter to determine how
hard your alternator is working. The LOAD meter works during flight. It tells you how many amps your alternator is putting out. That is important. It does nothing with with the engine not running or alternator off line. (
Load meter between alternator and first relay or in your case the Bussman fuse.)
The BATTERY (amp) meter (like a Cessna with center and +/- scale) only works on the ground when the engine is not running. It only tells you if the battery is being charged or is being drained. In flight after the battery charged and is just sitting there, so the LOAD meter just sits there doing nothing. Boring and no info that is useful on a daily basis. (
Battery meter between battery and buss. If you have multi busses that feed in parallel or dual batteries you are not going to be able to monitor all that with one shunt.)
Some justify the battery meter because if the alternator goes they SAY they will know how much drain they have. Well hooey.
A Battery (amp) meter will not tell you have long you have left. The volt meter is more critical at this point, post alternator failure. If your alternator goes off line, you shed nonessential load and land. You should know about what your drain was. It will be what your load (amp) meter said before you lost the alternator. However you should know when you get to essential items what your amps are and how long you can run on battery alone. More about that below.
A LOAD (AMP) METER IS EASIER TO INSTALL AND GIVES YOU MORE DAY IN AND OUT INFO THAN A BAT METER, IMHO.
WHAT IS MORE IMPORTANT is voltage with the alternator off line. The VOLT meter and voltage give a direct battery SOC, state of charge. For an Odyssey battery the SOC schedule is:
Approx SOC numbers (see Odyssey owner manual for chart)
12.8 volt 100%
12.6 volt 80%
12.2 volt 50%
12.0 volt 34%
11.8 volt 20%
You get down to 10 to 11 volts, things will get start to go dark. Some electronics will work well below 11 volts. Most Garmin will go down to 10 volts.
SOC is the capacity in precentage. There is no need to get into detail but in general if you keep the same CURRENT or AMPs the battery will discharge at a faster and faster rate.
If you are flying sans alternator you are not going to break out the calculator and do math to determine the time you have left. To be fair voltage is not really going to tell you much, but if its falling fast and getting into the mid low 11's you are going to run out of juice sooner than later.
ALSO to be fair knowing your AMP drain with a BATTERY (AMP) METER (no alternator) IS NOT GOING TO TELL YOU HOW LONG YOU HAVE LEFT EITHER!
HOWEVER you should have a good idea of what you MIN essential current drain is. The Odyssey PC680 should last. Odyssey published drain time from fully charged 100% to 10.02 volts at 10 amps of a little over 1-hour. That voltage is real low so let's split the difference, say 11.5 volts, you should about 30 min to from 12.8 volt peak to 11.5 volts.
My MIN emergency drain, electronic ignition, electronic flt/eng instruments, mater relay, Com in receive totals 4.2 amps, practical 5.7 amp load with transponder. Any lights adds from at. All I know is I have about +30 min with 10 amps, assuming the battery is in good condition.
