Old 03-10-2008, 09:42 PM
swaltner swaltner is offline
Default Software for Creating Wiring Diagrams on Macintosh
I've read through the forums looking at posts on software for creating wiring diagrams and found several suggestions for software that runs on Windows. It looks like many have gone with the ExpresSCH software package.
Since I don't have a computer that runs Windows, I'd rather find a package that runs under OS X. I can run the Windows software if necessary, it's just a hassle to do it, so I was looking for alternatives.
Suggestions anyone?
Steve
Steve Waltner
RV-8A (Under Construction)
Old 03-11-2008, 04:50 AM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
Try DesignWorks Lite from Capilano Computing. It costs $39, but there is a free demo that will work for 30 days so you can try it out. Be sure to work your way through the tutorial, as some aspects aren't obvious.
I didn't discover DesignWorks Lite until after I had completed my schematics using AppleWorks. AppleWorks did the job, but DesignWorks Lite would have been much easier, as once you connect items together with wires, you can drag the items around on the page and the wires stay connected to each item. That would save a lot of time when you need to add one more part, and find that you must reorganize your schematic to make room for it.
Kevin Horton
RV-8
Ottawa, Canada
http://www.kilohotel.com/rv8/
Old 03-12-2008, 07:11 AM
Thanks for the suggestion Kevin. I'll give it a shot this weekend when I get a little free time.
Steve
Steve Waltner
Old 03-12-2008, 06:08 PM
Gsuit's Avatar
Gsuit Gsuit is offline
Default Omni Graffle
Also give Omni Graffle a try... I've used it for some light schematic stuff, but it looks capable of more. It's no CAD (or probably even DesignWorks Lite) but it does the trick. Don't be scared away by it's main focus of flow charting... it has a wiring schematic side built in.
Clayton Henderson
Beaumont, TX
RV-7 N454CH (Flying)
Old 09-29-2009, 09:07 AM
GLPalinkas's Avatar
GLPalinkas GLPalinkas is offline
Default Apple Mac electrical diagram software
I have recently discovered a great program (I think it must be new) that allows drawing your personal electrical diagram using an Apple Mac OSX. EazyDraw
You have a choice of the FREE version which limits the number of objects placed.... but you can get a feel for the program....or
$20 - 9 month version - Full version use for 9 months. This version allows most builders to get the job done relatively quickly and not pay for yet another piece of software they are going to use once.
The full version is $95.
I opted for the 9 month version and also picked up the additional library package for a total of $30. The library packages include all sorts of technical and drawing libraries. You can check them out on the EazyDraw homepage.
EazyDraw is a very powerful program but for guys like me that want something simple and quick it also accommodates us.
Check it out at: http://www.eazydraw.com/index.htm
For those who are interested, I am modeling the Z-11 generic light aircraft diagram from AeroElectric and making my changes as necessary. I started using just a pencil and paper but any changes resulted in "eraser dust" and a crappy looking diagram. Changes in the EazyDraw diagram are simple and quick and the program doesn't require you to be a CAD engineer to figure out.
Output can be any number of options including pdf. You can check out my "work in progress" at the following link: http://files.me.com/glpalinkas/dr3box
It will download a pdf of what I have done so far (in just a few hours).
If anyone is interested in the complete EazyDraw file (and you are buying the application) and are basing their RV build on AeroElectric Z-11 I can supply the file to them, so they don't have to reinvent the wheel. Just drop me a pm.
Gary Palinkas - Gman.... VAF #161
Venice, Fl
RV-6 "Sassy" Flying 400 hrs since Oct 2011
Lycoming 0-360 A1A, FP Sensenich Prop
SARL #19 .... Van's Calendar March 2015
Although exempt several ways, =VAF= Dues paid to support this awesome site/family
