I was carelessly polishing a piece of metal in the shop the other day. Fortunately it was not RV-related - just a bracket for a dramatic prop my daughter wanted for a play she is involved in. I let the piece slip and it went under the wheel where it jammed momentarily between wheel and bench before being shot at the wall behind the benchgrinder with spectacular force .
The problem is that it tore a small chunk out of my Scotch-Brite wheel, which now vibrates and is very unpleasant to work with.
Has anybody found a way of re-surfacing these wheels? Without actually trying it, I guess that the Scotch-Brite will instantly dull any sharp or abrasive surface that you present to it. However, it is a shame to just throw it away.
