Old 01-28-2008, 07:25 AM
FrankK90989 FrankK90989 is offline
Default DIY tube bead roller
After sending in my Dynons to get the bright screen option I wanted to make some custom fittings for the static & pitot lines, I had used nylon fittings before and don't like them. I made the fittings using brass copper and some silver solder, but needed the tubing beaded. So I made two bead rollers, the tube cutter version works better see photo. Cost $5.00 for elcheapo tubing cutter and just pennies for the rest. The pins are made from a grade 8 bolt.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 01-28-2008, 07:56 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default wow
great idea. i think i'll make some
William Weesner
Old 01-28-2008, 07:58 AM
pierre smith's Avatar
Default Sweet.......
Since you're flying you must be trying to satisfy a little builders' withdrawal
Nice work. Did you machine the bolts down to get the raised section that makes the bead?
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-28-2008, 09:21 AM
Default One more idea
Fit a tube over a small screwdriver to keep it on these *#@# screws, I used a drill bit shank and made a couple one short one long #19 drill bit works.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 01-28-2008, 09:33 AM
Pierre,
Yes I turned them on my new H.F. mini lathe, my other lathe is to big for the small stuff. The little H.F. lathe actually works quite well, very good runout on the supplied chuck. Builder withdrawl big time---been real close to ordering a -8
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 02-11-2008, 11:18 AM
G Swartley's Avatar
G Swartley G Swartley is offline
Default Nice
Frank any ideas of making a few of them and selling them here. I would be interested since I don't have a lathe.
Gregg Swartley
RV-9
Bowmansville, PA
http://www.greggswartley.com
Wings (Done for now),
Working on the Finish Kit
Old 02-11-2008, 01:02 PM
AllanC AllanC is offline
Greg,
In case you are interested, Franks has a great little lathe which, for its size and price is an incredible buy. I have had one for nearly 10 years, and found it tp be perfect for this kind of small machining therapy. There is also an active HF Minilathe yahoo forum as well, with all kinds of active memebers and projects. HF also supply an incredible small desk top milling machine as well, which again, for its size and price is very capable. Both lathe and mill are under $500 each, although I think there are other suppliers of the same mill for even less.
Allan
