Steve Brown
Hi All,
I've read many of the posts regarding using something bigger in a 9. Only a few seem to touch on the use of a bigger engine with a fixed pitch prop.
I have a slightly modified O-320 with Catto 3 blade FP on my 9A. For years I've been mostly flying CS prop airplanes and before the 9A, had never flown a FP airplane with good performance. Here are a few obvious things I've gleaned out of that relatively short experience:
-You can't exceed the recomended TAS of the airplane, as long as you stay under engine redline. This assumes you have the prop pitched for Van's airspeeds.
-A bigger engine won't use more fuel in mid altitude cruise. You will be producing the same HP as with the 320. Otherwise will exceed redline.
-At low altitude cruise, you could burn more fuel, but that can be fixed by pulling out the black knob a little. Same with high altitude (>15k) Just control yourself
-A bigger engine won't use more fuel climbing if you climb at the same airspeed. Drag will be the same, the extra HP will use more fuel, but for a shorter period of time.
-A Catto in front of a 360 may weigh less than a CS in front of a 320.
-The cost trade, like the weight, is probably a wash. Cheaper prop, more expensive engine.
Anyway, as long as you use a FP prop (pitched to Van's airspeeds) and pay attention to the total FF weight, I see no risk associated with disobeying Van's on this point. Here is why I would want to do it:
-Maintenance with the FP will be simpler and less expensive
-Flying behind the FP is simpler. More than half my hours are behind CS (over RG), but I don't miss it a bit. Especially my instrument flying has improved with the reduction in complexity.
-A bigger engine will climb better and have shorter takeoff roll. This can be an advantage when its hot at high elevation airports, when trying to climb over weather, etc.
-You can maintain low 160s TAS to higher altitudes (16k, 17k, etc)
-A bigger engine will be running at a lower % of power in cruise (most of the time), and will likely last longer.
-The bigger motor will be run with greater detonation margin, possibly making LOP at higher airspeeds possible.
Have I missed something or is it perfectly ok to use more HP with properly pitched FP in a 9?
