I have a bit of aileron snatch only in rough air, any ideas? Gary
Please describe exactly what happens. Aileron snatch is condition where if you put some aileron input in, and release the stick, the stick will go to full aileron deflection and stay there unless you pull it back to centre. Is this really what you mean, or are do you have another problem?I have a bit of aileron snatch only in rough air, any ideas? Gary
So basically you need a tight radius, but squared off, edge on the TE of the aileron (and I'm assuming rudder as well)?
Have you flown in other RVs in similar conditions, and if so, how did they compare to yours? How much friction is there in the aileron controls of your RV, as compared to others?the ailerons move just a bit in rough air, the stick will deflect about an inch in either direction, I can slap the stick, it will react then center, it is just a bother that in rough air the stick wants to move in my hand slightly. I will try pinching the trailing edges a bit, any other ideas? thanks, Gary
