Rick6a
It is generally accepted that it is best to keep bends as gradual as possible when routing hose from the pitot tube to the back of the instruments. Still, it would certainly ease installation if I terminated the soft aluminum tubing from the pitot tube into a right angle bulkhead fitting (installed in the fuselage) then continue the run to the back of the instruments with plastic or nylon tubing. Is this an acceptable plan, or is that right angle bend in the bulkhead fitting just too severe for this application?
