GAHco
Loose Gear Leg Bolts, Would this help?
At the E-mail request of an established RV Customer of ours.
Concerning the loose fit of the Bolts / Holes attaching the Nose and Main Gear on most RV's (may or may not be applicable to yours)
The suggested solution is to put in oversize bolts after Reaming (Not Drilling) the proper size close tolerance holes.
Matching the grip lengths of the following for the Nose Gear.
AN5-20A has a grip of 1.563 inches, times that by 16 to get a 25/16ths grip
For a standard close tolerance equivalent bolt you would use an NAS1305-25 or NAS6605-25
For the first oversize you would want to use the NAS6605-25X.
We have the NAS6605-24X, this should work very well if you use only one washer or thin washers, the installation is in shear so all that needs to happen is the bolt needs to fit very snug and not fall out.
Matching the grip lengths of the following for the Main Gear.
AN5-22A has a grip of 1.813 inches, times that by 16 to get a 29/16ths grip
For a standard close tolerance equivalent bolt you would use an NAS1305-29 or NAS6605-29
For the first oversize you would want to use the NAS6605-29X.
We have the NAS6605-29X, this should work very well, the installation is in shear so all that needs to happen is the bolt needs to fit very snug and not fall out.
I have reamers but they are for installation in Aluminum for a medium drive fit, you need this to be an exact fit, not under or over. Any machine tool supply such as MSC could accommodate you on these.
The reamers I do have are .3105, .3261, .3417, you can use them if you want, but beware, if the bolts are on the high side you will have a pretty tough time banging them in.
Be careful not to drill these holes out to there final size, you want to ream them.
Do not make your first oversize hole too big, but if you do, I have the NAS6605-27Y, no room for washers on these for the Main gear, and several washers for the nose gear.
The Bolt dia specs for the NAS bolts are
6605 normal = .3110 to .3112
6605 (X) = .3266 to .3276
6605 (Y) = .3422 to 3432
Most of these items may be purchased on our Webstore or you can call and ask for a sales person once you have determined the part numbers you want.
Hope this all helps. Tom
If I were to see enough interest I would consider a repair kit with the first oversize bolts and the proper reamer for the 4130 steel. The reamer would not be the turbo fancy cobalt, like I already have , but one that will do the job without costing you a leg (pun intended).
Let me know if you are interested, I know many of you just need the bolts and already have your own reamers.
