I have a 9A and I'm working on the fuel lines from the valve to the wings. The plans show the lines going through the bottom grommets but when trying that route the gear weldment obstructed the grommet opening on the brackets that hold the covers in place. I opted to use the top grommets which are larger but the route seems much easier. Is this Kosher? Also, I had to make a pretty sharp bend to line up to the fuel valve and I ended up with a very slight flattening of the line. Not enough to affect flow or rigidity (I'm assuming) but ever so slight...is this acceptable? Thanks all!!
