Old 11-07-2007, 08:26 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Baggage Door Questions
I'm pleased how well the baggage door came out but I do have a few concerns about improving its basic design a bit. To prevent water from entering, I want to install a good seal around the door's sides and thought about using something like this: http://www.trimco.info/images/Illust...kets/S2123.jpg Is there a better alternative?
Also, Van's suggests "an optional closed cell foam" may be installed underneath the hinge....how exactly do you do that? Where do you get the foam and what type adhesive (if any) is used to afix it?
Finally, the door begs for some sort of strut to hold it open...what are builders using? Is there an off-the-shelf strut I can use?
Ideas, thoughts and pictures sought, especially from -8 builders who have been there and done that.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 11-07-2007, 08:41 AM
briand's Avatar
briand briand is offline
Default From Jim Daniels Site
http://home.comcast.net/~jwdweb2/Finish7/finish7.html
Old 11-07-2007, 12:42 PM
Tom Navar Tom Navar is offline
Default baggage door holding device
Rick: I installed a "spring thing" on my Baron's baggage door, and it works great. Check it out on performanceaero.com. Basically, it is just a long spring
with a thin cable though it, which attaches at either end to the door and to the airframe. When the door is raised, the spring holds it open; to close the door, you simply grasp it midways, tug, and the thing folds over, allowing you to lower and close the hatch. IMHO, it looks better than the hardware store device., and it is relatively inexpensive.
Tom Navar
RV-8QB
Working on flaps
Old 11-07-2007, 08:13 PM
jthocker's Avatar
jthocker jthocker is offline
Super Moderator
Default Gas spring
Larry Bowens website has a link in the archives from McMaster Carr for a gas spring that works.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Redline Air Shows
http://www.redlineairshows.com
Upgrade your RV from "Steam" to "Glass"
http://www.redlinethegoal.com
Old 11-08-2007, 01:04 PM
Rick6a's Avatar
Originally Posted by Tom Navar View Post
Rick: I installed a "spring thing" on my Baron's baggage door, and it works great...... . IMHO, it looks better than the hardware store device., and it is relatively inexpensive.
Tom .....
Thanks for the really great tip Tom! I ordered the "Spring Thing" yesterday right after I read your post....http://tinyurl.com/3543uc....and received it less than an hour ago. It took all of 15 minutes to install and works perfectly.
Now if I can just get answers for my other two questions.
Thanks again.
[/url][/url]
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
Old 11-08-2007, 01:09 PM
Rick, looks cool.
I had a similar setup on the baggage door on my Stinson, worked great.
One word of caution, put some anti-chafe covering on it-------clear vinal tubing worked for me, the spring can really mar aluminum.
Old 11-08-2007, 02:25 PM
MSFT-1's Avatar
MSFT-1 MSFT-1 is offline
Default I am not sure you need anything...
My RV-8 with a standard Van's baggage door seemed to be completely waterproof. When I flew it in the rain and in the clouds I never got a hint of water in there. I did get some water into the cockpit via the NACA vent though.
I like the spring thing idea. My RV-8 had a simple chain that kept the door from opening too far (when fully open it was overcenter on the hinge thus keeping it open). This was a fairly poor idea since even a slight wind would close the door (usually when I had my head in there).
One thing to think about is the door opening in flight. It happened to me once. It is not a traumatic event (in fact it stays closed until you slow down then it slowly opens almost magically). I thought about an idiot light on the panel but ended up just adding a checklist item to my run-up: "visually ensure that the baggage door is closed and locked".
Bruce
Richmond, VA (KFCI)
RV-10 (520+ hours since first flight in Nov 07)
RV-8 (500 hours, sold Sept 07)
Old 11-08-2007, 02:51 PM
N908RV's Avatar
N908RV N908RV is offline
Rick,
I just used some standard household grey closed cell foam that is used for weatherproofing a window, etc. I had to double the standard size up to get the thickness though. It just goes in the door hinge U channel stiffener and basically serves to keep water from getting past the eyelets in the hinge.
I have had my RV out on the ramp for overnites in stormy weather and have flown through rain and never had a hint of water entering the compartment.
For my prop rod, I used the Jim Daniel method and just painted the fake brass thingamajig black to make me feel better.
Ditto for me on the anti-chafe tape - I used it on all the surfaces that overlap (fore and aft and where it overlaps the fuselage side) as otherwise you do get some paint rubbing.
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB in progress - finishing kit
http://www.mykitlog.com/N908rv/
Old 11-08-2007, 03:41 PM
rv8guy's Avatar
rv8guy rv8guy is offline
I used a McMaster strut and set it up so it holds the door open, and when closed, tends to hold it closed with an over center type of mount.
Works great, but the 5 lb strut is maybe a little too weak
I got the idea off the web, but cannot remember which RV-8 builder I borrowed it from
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 11-08-2007, 03:42 PM
Rick6a's Avatar
Originally Posted by N908RV View Post
....Ditto for me on the anti-chafe tape - I used it on all the surfaces that overlap (fore and aft and where it overlaps the fuselage side) as otherwise you do get some paint rubbing.
Guys,
Are we comparing apples to apples here? Your posts make me wonder if the design has slightly changed. The kit, received March past may be different than yours.....maybe my kit incorporates a redesign in that area because so many builders experienced difficulty fitting the door. You see, there is NO fore and aft overlap.....only along the bottom edge does the door overlap. There is no need for anti-chafe tape along the sides because when the door is closed, a small gap remains between the door and the skin. I have to believe that when exposed to a serious driving downpour, rain can and will surely enter into the baggage area. After all, a gap is a gap is a gap...is it not?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
