Addicted to the site?
Donate yearly (please).
Advertise in here!
Today's Posts | Insert Pics
Old 07-04-2005, 03:59 PM
zsadecki zsadecki is offline
Default Better to dimple or countersink?
Since I've started my wing kit, there are several places (on the rear spars) where I've run across a choice of dimpling or countersinking. So my curiousity led me to ask this question of whether a countersink or dimple makes are better (stronger, less prone to any trouble later) joint? To venture a guess, I'd say that dimples are better since you don't actually remove any material and that leaves more to support the rivet. But the more interesting question is for a 3 (or more) sheet sandwich (for example, doubler-rear spar-rib). Is a triple dimple better or is a dimple-countersink-flat joint better? My guess is dimple here again, but I'd like to know what some of you other (more experienced and/or educated) guys might think...
Zach
7A Wings - N7ZS (reserved)
http://www.n7zs.net/
Old 07-05-2005, 06:10 AM
Mel's Avatar
Mel Mel is offline
Super Moderator
When faced with a choice, DIMPLE!
Mel...DAR
Old 07-05-2005, 09:57 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Zach-
For the case you mentioned, rear spar to doubler to rib, I checked with Van's and dimpling all 3 layers was the way they recommended--for the reasons you mentioned as well. I saw another builder actually countersink but, if I remember correctly, on the -9, countersinking was not an option because one of the layers (the doubler) was not thick enough for a countersink on a 1/8" rivet. There the layer you are countersinking needs to be .052 for a 1/8" countersink (if I remember section 5 of the manual correctly), yet it was something thinner I think. If possible, I always dimple. BTW--the rivets set very flush, even through 3 layers.
Steve
Steve M.
Ellensburg WA
RV-9
FWF wiring and plumbing
Old 07-05-2005, 01:36 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Dimpling will produce a better result usually. When doing multiple overlapping skins, IF the skins will support countersinking, I will countersink the bottom skin and dimple the top skin. Dimpling on top of dimpling tends to produce a small bump that can be noticeable when painted. But if the skin is too thin to countersink, then just dimple both and move on.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
RV-12 - Under consideration
427 Shelby Cobra - Under construction
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 07-05-2005, 03:47 PM
That's what I ended up doing. Dimpling all 3. Even though the instruction say "machine countersink", but the doubler and spar are both .040. One of those "don't take the instuctions literally" places, I guess...
Zach
Old 10-31-2005, 02:40 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Send a message via Yahoo to RV7Factory
I am there now, and after reading this post I think I will dimple. For once I am glad I made a mistake by forgetting to countersink yesterday... I love this site!
I do however have a related question...
Should the flanges of the spar and doublers be dimpled now, where they overlap and the skins attach? It seems like it would be easier to them dimple now rather than trying to dimple two layers of .040 at once, although I have never tried.
Thanks!
Brad Oliver
Livermore, CA | RV-7 | Fuselage | N609BC
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Twenty years from now you'll be more disappointed by the things you didn't do than by the ones you did. ~Mark Twain
Old 10-31-2005, 05:28 PM
Thanks!
Yes, Brad. If you are going to dimple those parts (which I would recommend) do them first. It's pretty easy to dimple already layered joints where the material is thin (ie. spar plus rib or spar plus skin) but those doublers or the rear spar would likely distort if you try to dimple both thick pieces at the same time.
Good luck.
Steve M.
Ellensburg WA
RV-9
