Oil Cooler - Again (Just comments)
N520TX
This is an issue that's been on my mind to do something about for a while but was just too set in the "not broke, don't fix it" mentality.
As anyone who went to LOE knows, central Texas has been hot lately - that's nothing new, it's always hot here in summer. Well, during the flight there and back; while at 9,500 and 10,500 respectively; my oil temps were running about 210ish give or take with a fuel flow around 10-11 gph. I could lean it some more, but then the oil temps obviously go up. It always runs like that in the summer here and I just didn't give it a second thought.
That all changed yesterday. My neighbor here flew out to Midland in his 50 yr old Bonanza V35 with its 6 cyl Contintental bangin away. When he returned, we talked about the flight where he relayed to me the fact that he was burning about 10gph - for a 6 cyl ! Well ... that doesn't sit well with me. My O-360 4-cyl fuel burn was greater than the larger engine.
Of course the reason is due to running rich - due to the high oil temps. My baffling and seals are in great shape (I think) - so I need to find the other reasons for it. I recalled a thread by DC on his web site a while ago about swapping out for a new cooler. After digging a bit on rvproject, and on this site, I found all the details - and sure enough, I'm running a cheap Positech ($165) oil cooler. I admit it, I chose that cooler based on PRICE alone. I mean the SW is $450 .. is it really THAT much better at 3 times the price ??
Based on all the evidence I've read, I've come to the conclusion that the answer is YES. Not sure why it took this long to tackle, but the straw that broke the back was obvious. So far, I have 300 hrs (+-) on my RV, and figuring an average fuel burn overage of 1.5 gph, that is an extra $450ish of gas burned that I didn't need to. That alone pays for the better cooler. The order for the SW-8406R is going to go out today.
Just thought I'd relay a story - perhaps someone might find it usefull.
He could have been at 6gph. Has as much to do with the black and blue knob as the red one.
No Free Lunch
I admit it, I chose that cooler based on PRICE alone. I mean the SW is $450 .. is it really THAT much better at 3 times the price ?? I've come to the conclusion that the answer is YES. The order for the SW-8406R is going to go out today.
You get what you pay for. The cooler is one of the MOST important accessories for the engine. The alternative engine guys brag about how better water or liquid cooling is. Well Lycomings are liquid cooled, OIL. The more efficient and higher capacity the oil-cooler, the lower the temps at the valves. The valves (especially the exhaust valve) are oil cooled (and fuel another liquid). If course air over the heads is important. What you read at your Oil-T gauge is about 20-25 degrees (F) lower than what the TEMP is at the valves, so 210F is really 235F! You start to break down oil like crazy at those temps.
A Porsche, air-cooled 6 cyl +300HP Horz opposed engine, are air & OIL cooled and have +16 qts of oil & two large oil coolers. The BMW "boxer" air-cooled twin motorcycles are air and OIL cooled; BMW says so right in their technical specs. The Police version of the BMW motorcycle has a much larger cooler for slow driving.
DON'T GO CHEAP ON THE COOLER, BUY THE SW.
DON'T USE VANS REMOTE COOLER KIT; 3" SCAT IS TOO SMALL & PLENUM POORLY DESIGNED FOR ALL BUT 320's IN MILD CLIMATES. IT CAN'T FLOW ENOUGH AIR TO FEED THE SW COOLER.
Over Cooling
I would guess that there are almost as many "cheap" oil coolers "over cooling" as "under cooling". Not sure of all of the factors associated with that, but I believe it has less to do with the oil cooler than with the plenum and who knows what. My "cheap" vans oil cooler is partially blocked off in the summer and still never gets above 185deg on a 95deg day. I am going to try Van's shutter for this winter. My cooler is mounted as high as will allow on the baffle, which I also believe is a significant factor. (IO-360 180HP, RV6, V-induction)
No doubt, from the many posts, the SW cooler cools better. That would be the opposite of what I need, so, my "cheapo" cooler is better for me.
One thing I did that may make a difference, isolate the cooler from the baffle. I used baffle seal material like a gasket. It may make a difference by allowing less heat transfer from the baffle to the cooler. Makes sense that heat from the cylinder head transmits into the baffle then into the oil cooler flanges heating the whole thing up. Given that cylinder heads are running at +- 300 deg., it kind of makes sense. Perhaps I need that heat and shoud remove the gasket and see if my oil temps warm up?
So, you might try this first. I am sure others would be interested in knowing if it helped.
If your engine squirts oil on the piston skirts, definitely don't skimp on the oil cooler! In my book, that's the biggest factor.
That said, this talk about running rich to keep oil temps down...I don't subscribe to that theory. I'd rather run at PEAK EGT than 100F ROP if my engine is running hot (or obviously LOP if you *can* run LOP). I know some non-believers out there will think I'm nuts. Hey, it's your fuel, your engine.
And how high is too high? If your engine's oil runs at say 210F all day long but your CHTs are cool, what's wrong with that?
Would you rather dump your engine's heat into the oil which gets changed every ~50 hours, or would you rather your cylinders take the brunt of it?
Personally, I think a lot of the "you gotta keep your oil under 200F" stuff is overblown.
If you are running an IO engine with Gami injectors, you can run LOP just as cool as ROP. You sacrafice a few knots but save all that gas and you build up less stuff on the plugs and elsewhere. I just wouldn't do it above 75% power.
Cooler. But you don't need expen$ive GAMIjectors to do it. Just balance what you've got. Call Airflow Performance to get you set up for waaaay le$$ than GAMI.
Are Vans oil coolers failing?
Never heard of Vans oil cooler failing have you? If it works, maybe too well, is that skimping? I am sure I would feel differently if I had high oil temps. I'll change it tomorrow if I hear that they air failing and causing loss of engine oil. To my knowledge, there are thousands of them out there working just fine. Correct me if I am wrong. I can take it.
oil cooler boundry layer
Hi gang from the hot PHX desert.
I lowered my oil temps by following Ken's suggestion of shimming out the oil cooler 1/4" off the back of the baffling. This gets the oil cooler out of the cylinder cooling air boundary layer which tends to add heat to the bottom part of the cooler thus raising oil temps. It sounded too simple, but Ken encouraged me to try this first. It lowered my temps about 20 degrees and put them right in the normal range. BTW I am using the Vans oil cooler on my ECi Titan IO 360 with good results in the Phoenix desert. :)
Don
RV 7
Stellar Airpark (P19)
Phoenix, AZ
Here are two pictures of the oil cooler on my 180 hp IO-360 RV-8 built by someone else.
[/url][/IMG]
[/url][/IMG]
In 100 degree air I can crusie climb and oil temp gets up to 220 or so, and oil pressure drops to the low end of the green arc. It's manageable but I'd like to see a little lower temp so I could climb faster when I need to or just keep temps down for engine life.
Does anyone know the mfr of it? It looks like it's a nine row cooler. I did not get much documentation with the aircraft and most of it is stock Vans parts so perhaps this is the stock Vans IO-360 cooler.
I will try the suggestions in this thread about spacing the cooler back and adding some cowl seal as an insulator to see if temps come down a little.
That is the "standard" Vans "SW like" cooler that they ship with FWF kits.
I had the SW cooler and my oil temps were too cool (150-170). No oil squirts. Very mild OATs ( Pacific NW ). Changed to the Positec and now my temps are 170-190. So it really depends on your situation if the SW is an advantage irrespective of price. Two data points from my aircraft.
And NO that picture is NOT a SW type cooler.
http://www.aircraftspruce.com/pdf/2008Individual/Cat08298.pdf
Top left is the SW 8406R is the RV size, ( $531.00)
Bottom of the page right side is the type in the picture and the one in the FWF kits
They also sell a 8406R. ( $293.95)
They are NOT the same.
Thanks for all the great information. I've saved the page and noted the two coolers for future reference.
John
An Observation
[/url][/IMG]
[/url][/IMG]
In 100 degree air I can crusie climb and oil temp gets up to 220 or so, and oil pressure drops to the low end of the green arc. It's manageable but I'd like to see a little lower temp so I could climb faster when I need to or just keep temps down for engine life......
Your pictures illustrate the very same problem I encountered.
RV's are not of one design. The engine's relationship to its mount and its physical clearance to the cowling can vary... and sometimes quite dramatically. Van's own literature tells us when baffle mounting the oil cooler "higher is better." What I was easily able to do in my -6A (and it tends to overcool) is physically impossible in the -8. Look how low on the left rear baffle I was forced to locate the very same oil cooler in the -8. I scrapped several baffle parts learning that lesson. Note from the picture that I still had to remove a portion of the upper left corner of the oil cooler doubler plate just to provide marginal clearance with the upper cowl.
If flight testing proves the location untenable.....well then I'll just have to move it, but I'll worry about that later.
Those builders who are given to issuing blanket statements about the overall superiority of one oil cooler design over that of another manufacturer may well be missing a very important point.
Rick,
Do you have a picture looking at the baffle from the front? I'd like to see where the cooler opening sits in relation to the cylinder.
I agree that there are lots of variables that effect oil cooler effectiveness like position on the baffle. What cooler are you planning to use?
Thanks for the information in your posting.
John
....Do you have a picture looking at the baffle from the front? I'd like to see where the cooler opening sits in relation to the cylinder......
John,
Here's the relevant pics...nothing like a picture to illustrate a description. I had to seriously modify the newer style baffling and fastener callout and orientation in this area to get the FWF supplied oil cooler to fit.
I used the Van's oil cooler and baffle kit on my 7A with an 0-360. No problems with install, cooling, cracking , or leaking. I think a lot of cooling problems may be due to higher HP engines or poorly fitting baffle seals. Cracking and leaking could also be due to baffles too close to the cowl causing the baffles and/or cooler to hit the cowl. And vibration from a multitude of problems cold also cause cracking.
I have never had oil or cylinder head temp proplems. I run EI instrumentation and have calibrated it to ensure accuracy. I have never had any of the baffling fail either. Everything is as rock solid as the day it was built. I have the old baffle kit from 2003.
Roberta
I encountered exactly the same thing on my RV-8. I mounted it as high up as possible, but half of it is still blocked by the cylinder fins. I think the RV-7 upper cowl doesn't slope down as abruptly in this area, so the -7 builders are able to get the cooler higher up on the baffle without interference.
After a few hours of flying, I swapped my Niagra 20002A for a Stewart Warner 8406R. If I were to do it again (or remake the baffles), I'd go with a wider cooler. A fellow RV-8 builder I know used the wider (5" centers on the bolts) Niagra cooler, and he's never seen a temperature over 200F. I think having a not-top-of-the-line cooler that's wider gives much more cooling capacity than a top-of-the-line cooler that's narrower. Unfortunately, since I didn't want to remake my baffles, I had to spend the money for the latter option. It ended up lowering my oil temps 10-15 degrees.
Anyway, here is a pic from the initial installation that shows how tight the clearance is.
-Geoff
....I think the RV-7 upper cowl doesn't slope down as abruptly in this area, so the -7 builders are able to get the cooler higher up on the baffle without interference.....
Geoff,
Your statement is absolutely dead on and here's dramatic proof. The photo on the left is of Roberta's installation in a -7 series. Notice how high on the baffle Roberta was able to locate the cooler. The next photo shows the baffling I scrapped when I attempted to install the cooler in about the same place as Roberta's is. In this case the oil cooler protruded so high, I would have had to mold a blister on the upper cowl to allow clearance between it and the cowl and the area circled in red would have almost certainly failed anyway.
WOW!! I did not know that there was that much difference in the 8 cowl. That could surely account for cooling issues and the necessity to alter the placement of the cooler or enlarge it. Good Job Rick.
Roberta
My thanks to all for posting pictures and information. I have learned a lot. From looking at the -8 pics I think I see why ading a spacer between the baffle and the cooler helps. It gives the air more time to turn the corner past the cylinder into the lower part of the oil cooler.
Like I said earlier, I don't have cooling problems as long as I shift to a cruise climb in high ambient temps but the experimenter in me wants to try and lower temps a little. The wider cooler also makes sense.
John
George,
Thanks for your pointers. I'm starting an RV7 and will use the SW oil cooler. What cooler kit do you recommend in place of the VANs?
Henry Avent
4215 Oil Cooler
I looked through the packing list for the FWF kit for my RV-8 and the cooler is listed as "Oil Cooler 4215 Oil Cooler for IO-360." I posted a picture earlier of it. Is that the same as the "EA OIL COOLER II" listed at Vans?
Is that the same as the Aircraft Spruce 08-00740?
