RV-8A QB so I haven't had much fun with fuel tank stuff. I'm trying to install the float-type fuel senders that arrived with the first kit 2+ years ago. Not much room in the tank for measuring. In referring to drawing 16A, Van's gives the wire length dimensuions as "Approx. 3 inches" for both segments. However, the 1/2 scale drawing view shows them over 4". Supposedly there is a separate data sheet from Vans showing the exact dimensions, but I can't find it. Also, I checked the archives without finding dimensions, but found folks discussing different measurements for the left and right tanks. I'm clueless on that one.
Anyone know what the bent lengths were for your float senders?
Paul Valovich
N192NM Reserved (again)
Ridgecrest, CA
Paul Valovich
Ridgecrest, CA
