Rick6a
The FWF kit for the IO-360 includes two CT Q-60 quadant cables. One is to be used for the throttle and the other for the mixture. Both are 60" long. I routed the cables per plans long before the engine was installed. The throttle cable length was okay and installed just fine. Ditto for the (shorter) prop governor cable. The mixture cable seems to be way too long. I contacted Van's days ago and still no response. It seems that instead of being 60" long, the mixture cable should be about 52" long if it is to mate adequately with the VA-163 mixture bracket. Has anyone else run into this problem?
I reviewed Van's website and the CT Q-60 is called out to be used in this application. Something is not right. Why would a 60" long cable be specified for use here?
