Good point, That's why its Experimental
rv620mr said:
The Hartzel tech sheet, which is quoted above, lists tuned exhaust as having a potentially adverse affect on prop vibration and stress.
My sense is that most of us run tuned exhaust systems like Larry Vetterman's. I do. And, it's a great product. I see many threads addressing the potential impact of high compression pistons and electronic ignition on prop vibration and stress. But, I don't see much about tuned exhaust. Why?
Is the conventional wisdom that tuned exhaust has only a negligible impact on prop vibration and stress? I'm just lookin' to learn something.
Because no one really noticed, GOOD POINT!
Gold star....
It has been mentioned but I don't think any one has really flagged it or tested it.
You are right the 4-into-1 "tuned exhaust" or headers do change the flow, power and pulses, no doubt.
I did ask about high compression pistons. Engineers don't like to speak off the record, but off the record the engineer I talked to thought HC pistons do make small changes to existing limits, such as a little border or wider range (not much). He did not think it would shift the whole range up or down. Basically higher compression does not make wholesale large changes in the vibration characteristics but small ones.
I suspect exhaust (wild guessing on my part) would have similar affect as HC pistons, in that it will increase the HP slightly. The cross-over Vetterman is no slouch; it's way better than any stock Cessna or Piper exhaust system. However 4-into-1 headers do have a little more savaging and affect on the power curve over cross-overs. I doubt there would be any huge shift, change or new limits that did not exist already (like HC pistons). However the HOTTER the engine (further from stock) the more you have to think about the affect on a metal prop, more so with the 7496 than the 7497 blade.
Power Flow makes those 4-into-1 exhaust systems for certified planes? Did they do prop vibration testing on every airframe for those STC's? They claim 15% or 20 HP power increase! Its not MORE than rated HP. It does not turn a 150/160 HP O-320 into 170/180HP, it just gets back close to rated hp of the engine, overcoming the poor stock exhaust, which cost about 20 HP. Still I wounder did the FAA consider the affect on the props. They make Power Flow systems for Mooney's, which of course uses Hartzell constant speed props.
Your exhaust point is super valid. It's why certified planes are so picky about having the original configuration not be altered, with out all kinds of hoop jumping. The cause and affect can not always be predicted, so each and every change needs to be tested.
