Vern
Jerry McDowell and I (Vern Darley) pulled our RV's next to each other in the Falcon RV Squadron hanger this weekend and began upgrading our panels to newer technologies. Jerry has an RV-7 and I have an RV-6A. We both have O-320's and Sensenich props. We both had standard six pack steam gages and vacuum pumps. We thought that since there has been a lot of interest in the new Enigma, it would be fun to be like 'Click and Clack' and do a side-by-side comparison as we pull the old out and install the new.
What came in the Enigma box:
http://img517.imageshack.us/img517/4170/p9070014oa9.jpg
What came in the Dynon box:
http://img528.imageshack.us/my.php?image=p9070012dr0.jpg
It's 10 pm Ga time and Jerry just fired his new Enigma up. He basically worked all weekend and is not completely done, but when we pulled his RV-7 out of the hanger and started the engine, the Enigma came online and gave good engine data, a nice looking EFIS, and an internal GPS. I got my old panel out, cutout a new .090 aluminum left panel, fitted all my steam gages for backups except AI, DG, and VVI and installed the Dynon mount into the panel. After I get it powdercoated, I'll bolt back all into the panel. Most of my wiring is run.
Because I had other activities this weekend, I did not get quite so far along on installing the Dynon D-100 as Jerry did on the Enigma. Since it has it's own internal backup battery, I was able to 'fly' it around in the hanger as it came out of the box and would immediately operate. If I had spent as much time as Jerry, I think I would be at the same stage as he is.
We took pix of each unit as it came out of the box so you can see what you get for your money. We will upload the pix ASAP.
We each benefited greatly from having modular panels. It made upgrading our panels so much easier. I have a three section aluminum panel made by Fabian from Affordable Panels and Jerry has a molded fiberglass panel.
Jerry will add to this posting when he gets home. As we complete the install we will give our opinions regarding the two units. So, Jerry-weigh in!
Ask any questions and we will try to answer them.
