Brockster
I purchased a model 59-1A nose wheel assembly from Grove Aircraft and a 11x4.00-5 (Lamb) tire and tube from Vans. The reason I did this is I did not like the matco wheel bearing seal design. I believe the nose wheel should always turn freely and that the breakout force for the caster is the critical perameter to prevent shimmy etc. The problem I am having is the tire bead will not seat against the flange of the rim. I talced the tire, tube and rim and then assembled the wheel halves making sure the tube was not pinched. I then torqued the thru bolts and inflated the tire several times to 30 psi. The beads on both sides would only come to within a 1/4 inch of each flange but the side wall of the tire would contact the outer edge of the flange making it look as though the beads were all the way over. The reason I can tell they are not seated is I never got that pop you hear when they snap over and when I deflated the tire each time there was that 1/4 inch gap all the way around the rim on both sides. I even inflated to 80 psi (Rim can withstand 200 psi and tire 94 psi per manuf) and that didn't move it. After a difficult disassembly I measured the inside diameter of the tire and it is around 4 7/8 inches. Grove wheels are made to aircraft specs and outside diameter of the rim measures 5.020 inches. Speaking to the engineer at Grove, he agrees this is to much interfearence, but states several RV's and many Lancair's are flying with this wheel and tire configuration. My questions are:
1) Could anyone who hasn't mounted there nose tire on the rim tell me what the ID is to see if maybe I just got a defective tire.
2) What is the OD of the rim, not the flange, of a Matco nose wheel Vans provides. Maybe a true 5" aircraft wheel cannot accept a 11x4.00-5 tire and the Matco's have a smaller diameter for this reason.
3) If someone reading this is actually using this combination could you send me a message that I could contact you and ask you some questions.
Any help greatly appreciated.
