frankh
Ok I'll admit to the fact I'm becoming a little addicted to doing -ve G stuff...nothing brutal but I have seen -1.5G so far and expect to see -ve 2G when I do the inverted spin.
Anyway...I took a close look at the belts...I have the standard Vans 5 point harness and am very careful to make sure no piece of clothing can lift the handle.
In looking closer at the mechanism there is very little in the way of positive engagement that prevents the belt letting go.
I know there isn't that much force (300lbs or so) but even so its definatly a single point of failure which would almost certainly lead to total loss of control if it let go while upside down.
Anyone have any thoughts about adding a backup lap belt or someway of hardening this seemingly weak spot?
Frank
Frank
