Andrew Griffin
Member
G'Day,
I need some help with a conflict in information I have about sand paper.
I have read that certain sand papers or wet & dry papers can't be used on alluminium because some cause corrosion!!
Does Silicon Carbide paper cause corrosion on Alclad and alluminium or is this the paper I should be using (i've read different things on different sites?)
I've got a scotchbrite wheel and i've used that to round the edges and ends of the rear spar strengthening bars, now I just need to remove the milling marks. What are people using and how can I assure it won't cause corrosion? Vans says the finish should be like 400 grit sand paper but I'm not sure which sand paper to buy.
Any information on this would be greaty appreciated!!
