cln1owner
To all those that have installed a pitot tube in the bay outboard of the bellcrank bay:
Any photos or links you guys can provide showing how you routed/secured your pressure line(s) around the bellcrank assembly?
I'm planning a Dynon Pitot with AOA, so two lines. I've concluded that the pitot/AOA will function properly in either the inboard or outboard bay locations. I'm just trying to decide if it will be less of a hassle to route lines around the bellcrank or to fabricate another access plate next to the mount in the inboard bay.
