Old 07-16-2007, 10:21 AM
idleup idleup is offline
Default RG Battery replacement for a Gill G-25?
I am looking to replace a Gill G-25 and was wondering if there is a good Recombant Gas alternative to the G-25?
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 07-16-2007, 10:37 AM
Okay, I found a Gill G-25S that is a RG version of the G-25. Can I use it as a direct replacement?
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 07-16-2007, 10:49 AM
Sam Buchanan's Avatar
hall monitor
Why not use an Odyssey? Less weight, less $$$$, no acid, just need to add some padding to the battery box to take up the extra space.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 07-16-2007, 10:57 AM
It is for a Grumman Cheetah, not an RV. I want to use the closest direct replacement for the stock battery but in RG technology.
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 07-16-2007, 12:08 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Concord RG under STC
- Matt
Matt... buy a Concord RG-25XC from your favorite supplier. It's covered under STC# SA01250WI and is a direct replacement in the Grumman plastic battery holder.
Call Concorde Battery at (800) 757-0303 for STC details. They will usually send you the paperwork for your Cheetah serial number for no charge, then talk your friendly AI into filling a Form 337 for you.
Since it's sealed, you don't have to worry about the plastic hose venting outside any more...
Did this on my Tiger, I couldn't see the need for wet acid in the engine compartment.
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-16-2007, 01:54 PM
Thanks Gil, that is what I will do.
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
