Addicted to the site?
Donate yearly (please).
Advertise in here!
Today's Posts | Insert Pics
Old 07-09-2007, 07:47 AM
WSBuilder WSBuilder is offline
Default Externals?
Most fighter aircraft aren't any better than RV's for baggage, so they mount small pods on the hard points to carry luggage, beer and lobsters. Has anyone ever experimented with external pods for additional baggage? I'm considering adding a second "hard point" on the rear spar, inline with the tie down receptacle and building fiberglass luggage carriers. Should be able to keep CG neutral.
Bill Grant, A&P
RV-4: Wings finished, Fus jig built!
Old 07-09-2007, 10:30 AM
Rick6a's Avatar
Rick6a Rick6a is offline
I've long fantasized about some entrepreneur offering a fiberglass or carbon fiber external pod capable of holding a golf bag. The forward end could be hinged and capped with a propeller spinner and the back cap hinged for internal access from the back. Sure, the additional drag would be significant but you would just have to accept the fact that on some missions you will be traveling at 160 MPH instead of 180 MPH.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R
EAA Technical Counselor
Old 07-09-2007, 11:06 AM
flyeyes's Avatar
flyeyes flyeyes is offline
It's been done, but wasn't a commercial success. Look here for a really interesting videotape on the design and construction techniques.
James Freeman
RV-8 flying
Old 07-09-2007, 12:26 PM
Default Spot On!
Have you seen the video or have a copy? What can you tell me about the pod: size, drag, weight, attachment design, etc? Mainly, since I'm building the wings and could easily incorporate the aft hard point now, is it worth pursuing?
Bill Grant, A&P
Old 07-09-2007, 04:21 PM
flyeyes's Avatar
I bought the entire set several years ago. Absolutely worth the money IMHO. Unfortunately, I loaned them out (to another RV builder) and haven't gotten them back.
IIRC, the pods (one on each wing) were teardrop shaped, and hung under the wing on a pylon. The base of the pylon picked up the tiedown attach point, and wrapped around the leading edge of the wing.
The pods themselves extended slightly in front of the wing, and were maybe 4 feet long by 1 1/2 feet wide at their widest point. The nose section (like a rounded spinner) was removable.
If you are conteplating doing this, buying the video would be a complete no-brainer. It would still be a lot of work, but the education is invaluable.
James Freeman
RV-8 flying
Old 07-09-2007, 06:09 PM
sjjonesnz sjjonesnz is offline
Don't s'pose you've got any pictures of the pod in place do you?
Old 07-09-2007, 06:40 PM
panhandler1956's Avatar
panhandler1956 panhandler1956 is offline
Here's a pic from that site I found. Not bolted into place, but it gives you an idea. I love the concept, like drop tanks on a P51!
Brent Owens
Columbus, OH
RV-8 in progress
Working on finishing kit
Wings (99% complete)
Fuselage (90% complete)
Wiring (80% complete)
(90% done 90% to go stage)
N784DE reserved S/N #2614
My builder page
RV PARAPHERNALIA
Old 07-09-2007, 07:35 PM
Greenley Greenley is offline
Andy Grove at www.grov-air.com has built some of these in the past. I don't know if he would have any interest in resurrecting past projects or not.
Bill Greenley
Old 07-09-2007, 07:57 PM
AX-O's Avatar
AX-O AX-O is offline
What about something like this.
How to mount pods
RV4 with pods
Axel
Ridgecrest, CA
RV-4 fastback: http://www.vansairforce.com/communit...ad.php?t=39772
RV-4 fastback Pics: http://picasaweb.google.com/N704TK
Owner Assisted Dynamic Engine/Prop Balancing: www.alvarez-aviation.com
VAF 704
Old 07-09-2007, 08:23 PM
N941WR's Avatar
N941WR N941WR is offline
A friend's RV-6 has a pair of these. They pick up the wing tie-down and you have to install two plate nuts in the top of the leading edge for two screws.
For some reason he doesn't use them while taking long trips.
Bill R.
Putting the "mental" in "Experimental"
Huntersville, NC
www.repucci.com/bill/baf.html
