HI All,
I just wanted to report on a recent experience in my RV-10.
I built an RV-10 about 2 years ago and have the standard Vans electric fuel pump. I also have a return line going to both tanks through an Andair duplex selector via a fuel pressure regulator (FPR). The FPR allows me to dial in my fuel pressure exactly to what I want irrespective of usage / RPM / climbing etc, so my fuel pressure after the mechanical fuel pump to the injector is always constant, and the flow in my return line is variable and optimised for max cooling of the mechanical fuel pump. I run 98 RON ethanol free mogas that is always fresh and filtered through a Mr Fuel filter, and I have had no problems with water or debris in the fuel. I run the boost pump on TO / Landing and to prime, and have never had any signs of vapour lock.
About a week ago, I made a trip to a remote desert to drop some kit off to a friend who works in a remote safari camp. The strip there was very rough and short and the air and ground were so hot that putting the girl down was difficult. After a go around, I finally got her down and by now she was hot. Oil temp was 245 and CHT's were in the 400-410 range. After parking up I shut down and left the fuel selector on left tank (I normally switch it off).
After about 2 hours, I came back to the airplane and my normal hot starting procedure of fullest tank selected, primed with the electric pump for a few secs only and then crank while enriching mixture till she fires and runs, didn't work. The engine coughed but didn't run. Tried again, no good, after another 2 tries, with headset off now, I noticed that the priming sound wasn't right, the electric pump was running, but I couldn't hear the normal gurgling of the fuel and the fuel pressure with the pump running didn't go over 5-7 PSI.
Now I knew I had a problem and got into a panic! With over 200 miles and 8 hours of drive through bush country to the nearest town and no car around, getting help wasn't going to be easy, and I had only the very basic of tool kits with me (I normally have a bigger toolkit but I left it at base on the day). Still I decided to systematically try and diagnose and fix the issue. I had fuel in the tanks. I checked the filters, they were new and had no debris in them. removed the fuel lines to and from the mechanical fuel pump and found with the electric pump running, there was only a trickle of fuel coming out. I blew through the return lines and they were clear. With the centre console off, the pump was running and humming away on touch, but not drawing fuel through the filters. I then removed all the fuel line connections and removed the fuel pump thinking there must be some debris stuck in it. pump was completely clear and when run bare, generated plenty of suction as normal against my finger. Then the problem struck me... The non return valve that runs parallel to the fuel pump was stuck midway, and I could blow through the valve both ways. When disassembled, the plastic ball was stuck in the cage midway with no evidence of debris or any restriction. Once washed in a little bit of fuel and reassembled, it started working again normally.
I presume that the plastic ball in cage return valve allows you to prime and pressurise with the electric fuel pump (when closed) and then opens to allow the mechanical fuel pump to draw a column of fuel from the tank while bypassing the electric fuel pump. Stuck midway, the electric pump couldn't prime and build pressure and the mechanical pump couldn't maintain an air free column of fuel in the line to support a running engine.
Everything reassembled, fuel pressure shot up to 35 PSI with the electric pump on and the engine started first time. I took off and made it back home with no issues, and have since flown another 10 hours with no problems.
Anyone had an experience like this before? I personally think that in my case, that leaving the fuel selector on a tank rather than OFF on shutdown allowed vapour pressure generated in the fuel lines from a hot engine to back pressure and push the ball in the return line and stick it midway.
I learnt 3 things from this experience: Switch your fuel selector to OFF once you park up, especially when the engine is hot. Always carry a comprehensive enough toolkit with you when you fly to open up and check most things. Don't panic if you get stuck, be systematic and work through things.
Any comments welcome.
Safe flying and happy landings all
Best Amer
Best Amer
