Old 03-25-2020, 06:57 AM
Ender Ender is offline
Default What blind rivet did you use here?
There is a really tough to access rivet. Many folks online have said they either had a really nasty buck, or they blind riveted it.
I'm curious what blind rivet you used if you went that route. The grip is pretty long, so I think I can only use a cherry (can't use a Mk-319). I want to confirm if the NAS1097 cherry is the right one to use (considering its a 3/32 hold that is dimpled for a 426-3).
Thanks!
Building RV-14A
Flight Test Engineer
www.hikebikefly.com
Old 03-25-2020, 12:44 PM
mturnerb mturnerb is offline
Depending on the grip range required, you could use a MK-321BS.
Turner Billingsley
RV-14A FLYING, N14VB
Old 03-25-2020, 02:10 PM
I don't have a rivet gauge yet, but I think its a bit bigger than that. Closer to 0.125 to 0.15 I think.
Building RV-14A
www.hikebikefly.com
Old 03-25-2020, 02:28 PM
Raymo's Avatar
Raymo Raymo is offline
Ask a mechanic to let you borrow his rivet gauge.
https://www.aircraftspruce.com/catal...iboltgauge.php
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 03-25-2020, 02:44 PM
Yep! or just buy one. They guys I work with aren't at work anymore with everything going on!
Building RV-14A
www.hikebikefly.com
Old 03-25-2020, 02:58 PM
Ethanol1 Ethanol1 is offline
Default Bill Reed
Do they still celebrate Bill Reed day in Marion?
Mike York
President EAA Ch 25
Old 03-25-2020, 03:01 PM
@Larco Correct, but that is for a 0.25 in max grip I think, I'm curious was the min grip is.
That is also for a larger 120 deg dimple. The initial hole size is 3/32 with a 100deg dimple for a 3/32 rivet.
The CS4-4 expects a dimple that is similar to a #30 hole, but at 120 deg.
Thanks for the suggestions though.
My guess is that I will need to use one of the NAS1097 1/8 cherrys.
@Ethanol1 - Not that I know of, but I'm newer to Marion, mostly lived in CR. But I know who Bill Reed is .
Building RV-14A
www.hikebikefly.com
Old 03-25-2020, 05:46 PM
squarebush squarebush is offline
I remember that area being a real bugger to buck. With 2 people it is doable. Having a small tungsten bucking bar helps get in the tight areas and still provides some weight behind it.
Todd
RV14a
Henderson , NV
Working on: Wings
Fuselage ordered
N617CT Reserved
Dues paid 2018 X2; 2019
Old 03-25-2020, 06:05 PM
Yeah I usually have two people. I also have a small tungsten bar (I have a few) but it still just doesn’t quite fit right. Thanks though!
Building RV-14A
www.hikebikefly.com
Old 03-25-2020, 06:16 PM
mc607 mc607 is offline
May be too late but I recall backriveting those stiffeners on the bench before installing.
