I have finished for now wrestling with the forward canopy frame (call it a draw) and I'm working on the side and aft canopy frame. I have a few questions.
Is there any reason structurally why I can't trim off the forward canopy skin ears? If I'm going to glass the front of the canopy around to the side, I would simply place a keeper in the glass for the canopy. I believe Dan C. said that he would cut the ears off if he did another tipper.
The other issue I have is locating the pivot block on the canopy frame for the strut. I have two pre-punched skin holes that would interfere with the block placement as depicted in the plans. I don't believe I could get rivets in on both of these. Is there any reason that the aluminum pivot block shouldn't be located adjacent to the 613 splice plate? I believe this is a stronger point on the frame. This position should also augment the strut operation by yielding a slightly better leverage point.
