Old 02-12-2020, 04:54 PM
Sam_B Sam_B is offline
Default Firewall pass-thru
For getting cables and wire through the firewall, I like the idea of the doubletree ball pass throughs, but they’re a bit spendy. Seeing as how I own a lathe, and a milling machine, I was thinking of making something similar, since I have the stock around, and just have to take the time to cut it. I was thinking of making a tapered collet, a tapered hole for said collet to nest into, and a cap to squeeze the collet into the hole and tighten it to whatever wire/cable/plumbing needs to pass through the firewall. Slather it in the 3M fireproof adhesive before it all goes together to fill in the cracks. So my idea may be well intentioned, but not work in the real world, so I was looking for opinions here.
RV-8
Empennage done
Wings 90% done
Fuselage in progress
2019 dues paid
Old 02-12-2020, 05:56 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I turned a stainless flange on my lathe, riveted that on the left side of the firewall and passed all three cables thru one hole. Fill the flange with firebarrier. Simple and cheap.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 02-12-2020, 07:23 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Yes machine or fab a bushing.
+1 for Rocket Bob suggestion. Dan H helped me years ago and the little T bushings riveted and sealed with firebarrier are flawless.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 02-12-2020, 08:58 PM
Carl Froehlich's Avatar
Get the nice SS passthrough flange that comes in the RV-14 kit. Put a piece of fire sleeve inside the flange and a piece over the top of the flange on the firewall side. Wire runs in the middle of course.
Old 02-12-2020, 09:20 PM
fl-mike's Avatar
fl-mike fl-mike is offline
I’m using these with the Rocketbob fill.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They are welded stainless.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 02-12-2020, 09:40 PM
Default Little T bushings?
By ‘little T bushings’ do you mean the ones that come with the Vans kit?
RV-8
Empennage done
Wings 90% done
2019 dues paid
Old 02-13-2020, 05:49 AM
Northernliving Northernliving is offline
Is this the firebarrier you are using for fill?
https://www.aircraftspruce.com/catal...l2000caulk.php
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 02-13-2020, 06:13 AM
Tailwind/RVGuy Tailwind/RVGuy is offline
One thing to consider before you fill up your pass thru with fire barrier is whether or not you "might" be adding another wire or cable thru that hole in the future. If so, it will be significantly more work to pass it thru if you have it filled with fire barrier caulk. I used short pieces of 4130 steel tubing welded to a flange (similar to what fl-mike posted) I used a short piece of fire sleeve held in place with safety wire around the tubing and then another safety wire at the end of the sleeve wrapped tightly (no gaps) around the cables/wires/ I then used "rescue tape" around the wire and sleeve to prevent any gases to flow thru. In the event of a fire, the rescue tape would be worthless but the fire sleeve and safety wire should work pretty well until that particular area is not my main concern anymore.
I did use fire barrier around my heavy (#2) starter cable pass thru but knew that I would not be adding any more wires there. It is messy stuff.
Keith
Keith in Lacrosse WI area
Finished Wittman Tailwind in 2016
Flew RV9A and RV6a while building
lurking for years but now paid
Old 02-13-2020, 07:40 AM
Brdog42 Brdog42 is offline
Those who used this method for electrical wiring...
Did you use the same method for control cables? Throttle, mixture, etc.
Thanks for sharing something simple that works!
Tim
1973 A150L sold
RV-6A restoration in progress
KCHD AZ
‘’’’’’’’’’’__|__
*>—O-(_)-O—<*
Old 02-13-2020, 07:53 AM
DanH's Avatar
DanH DanH is offline
Yes Brian, that's the stuff.
Sam, I'm guessing you can weld. If so, tubular pass-throughs are easy to make in any diameter, as they are just a tube welded into a base plate.
I've run burn tests on them. When pumped full of Firebarrier 2000, they're as fireproof as anything you can do. Here's one at 2000F, still sealed tight:
The only one I've seen from Vans was on an RV-14. FWIW, I like the tube a little longer, but that's a nit. I snapped a photo of the RV-14 install because it illustrated a caution. Note the exit angle on the heavy gauge electrical wire as it leaves the fitting, rubbing against the edge of the tube. Don't want it to be like that in service. Also, I'm not real wild about Bowden cables and electrical wires in the same fitting. Bowden cables generally connect to the engine, which moves on the mounts. Hang around this game long enough and you'll see an example of a Bowden cable acting like a saw.
Works for everything Tim. Note that Keith's note regarding the difficulty of removing the silicone plug is valid. To remove the plug, just make a half-moon cutter from a length of tubing one size smaller than the pass-through tube, and force it through to cut the sealant perimeter. The firesleeve approach is also accepted in some certified applications, although perhaps not as fire-tough as the solid plug.
Dan Horton
RV-8 SS
Barrett IO-390
