jelliott82
Member
Hello
Second question for me today relating to G3X Canbus! What are you guys doing with running the Canbus out to the aileron servo in the right wing?
I have put ring terminal joiners on the seat floor ribs to connect all the wing wiring to (landing lts, position lts, strobe lts, OAT Probe, CanBus etc) and I have run 2 lengths of Canbus wire into the wing (1 in and 1 out if you like), connected to the Aileron servo as per standard Canbus wiring and then I have effective cut the Canbus (Hi, Lo, and Shield) at the wing root to join them together with the fuselage runs via a ring connector terminal block as per the photo.
So the question ... is this an acceptable way of handling the Canbus for the wing wiring? I am hoping this is what others have done successfully given I have already finished wiring it like this!
https://share.icloud.com/photos/0SxCNvVqzSUaRZhsdeytZZfLg
Jonathan
Jonathan
