Old 10-10-2019, 04:10 AM
jcl777 jcl777 is offline
Default 912iS-RPM Rise During Lane Check
I am a new owner of an RV12-iS ELSA, and am new to Rotax engines. During a lane check at runup, RPMs actually increase when Lane A is turned off, but decrease as expected when Lane B is turned off. Have no idea why that would be or if it indicates a problem.
Any thoughts?
John Leon
Kingwood, TX
RV12-iS, N221TF, #121130, non-builder
Old 10-10-2019, 06:02 AM
Maybe you moved over and pulled into highspeed lane?
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 542
LSRM-A Certificate 2016 for RV-12 N633CM
Old 10-10-2019, 08:21 AM
jrtens's Avatar
jrtens jrtens is offline
There is a 912iS forum on rotax-owner.com that might be able to help.
Jon
RV-12iS
Salt Lake Int'l
Old 10-10-2019, 10:08 AM
Default RPM Rise Seems to be ... Normal
Found these two interesting tidbits from two different threads in the forums at rotax-owner.com. Interesting.
The Fuel injected 912iS and 915iS engines use an ECM module that does NOT fire both plugs at the same time.
The Plugs fire alternately on every other cycle.
This allows the ECM to identify which plug in which cylinder might have a problem and remove it from the firing sequence with no power loss and the only indication being a warning light on the panel.
When performing an ignition check on these engines, the ECM fires the same plug on every cycle resulting in no rpm loss.
And because the ECM also enrichens the mixture slightly because it thinks there is an ignition failure, The engine RPM actually INCREASES during the ignition check.
Sometimes during lane checks the RPM will actually rise then once both lanes are back on it will decrease back where it was. The mixture is just going full rich and thus more power.
John Leon
Kingwood, TX
Old 10-10-2019, 10:14 AM
rvbuilder2002's Avatar
The RPM rise during ign. check on an RV-12iS is normal.
My understanding was that it was because of #2 below.
I have never heard of #1 (but that doesn't mean it is not true).
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
