Go Back   VAF Forums > Main > Temp / Test / Misc. (posts deleted after 2 weeks)
Old 10-08-2019, 06:22 AM
catmandu's Avatar
catmandu catmandu is offline
Default Thinking about a non-stop Atlantic crossing . . .
Just need a proper hard point (got a call into the mothership), plumbing should be easy.
If only I knew someone who could help me read the data plate.
Flogger tank, from Craigslist, FYI. Probably gonna become a cooler for hangar parties.
Mike C.
Maryland's Eastern Shore
RV-6A bought flying
Old 10-08-2019, 07:09 AM
emsvitil's Avatar
emsvitil emsvitil is offline
Some guesses:
82E1125, serial number
1 ATM 1 atmosphere, can't be pressurized
61.9 KT, can only go 61.9 knots
800 ?, capacity, lbs,kg,gallons,liters ???
Manufacture date 23 6 82 or 23 June 1982
Ed
Old 10-08-2019, 07:11 AM
rmartingt's Avatar
rmartingt rmartingt is offline
Iím guessing 800 liters and 61.9Kg empty?
RV-7ER - finishing kit and systems installation
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 10-08-2019, 07:36 AM
sbal0906's Avatar
sbal0906 sbal0906 is offline
Using this: https://www.metricmethods.com/SI_russian.html, I'd say that's a good guess.
Shamit Bal
http://www.flyaroundthesun.com
RV-9A
Started on wings.
Winnipeg, Manitoba, Canada
Old 10-08-2019, 07:43 AM
Snowflake's Avatar
That's probably max RV speed with it attached.
Rob Prior
Old 10-08-2019, 10:08 AM
Norman CYYJ Norman CYYJ is offline
At least you have an A model the nose gear will prevent the tank from running interference with the prop.
Old 10-08-2019, 11:48 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Tank Number 82E1125
Pressure Limit 1 Standard Atmosphere
Empty Weight 61.9 KG
Capacity 800 Liters
Date of Manufacture (or certification?) 23 June 1982
Vlad, is that right?
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King ďBeautiful DollísĒ old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePo4.
Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 10-08-2019, 02:01 PM
humptybump's Avatar
I think you'll have the competition scrambling for cover at the next Easton bomb drop contest.
- Glen, ESVA
Old 10-08-2019, 04:23 PM
Vlad Vlad is online now
Originally Posted by scrollF4 View Post
Tank Number 82E1125
Capacity 800 Liters
Almost Colonel. Not pressure limit but rather normal (working) pressure
Mike how did you get it out of sandbox?
Old 10-08-2019, 04:36 PM
catmandu's Avatar
Sharing a 12 man stateroom with snake eaters has its benefits (I can also start an IV and field repair a nearly silent outboard motor)!
Mike C.
RV-6A bought flying
