Old 10-07-2019, 08:11 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Boarding step for tail dragger
Anyone installed the boarding step on an 8 tail dragger! Thinking about it as that first big step is kind of a pain. Pics please!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 10-07-2019, 08:15 AM
pdecraene7a pdecraene7a is offline
Default step
I have them on my 7 because I converted from an A to taildragger. It is good for loading kids and older people
Pete DeCraene
Joliet, IL
RV-7A CONVERTED TO RV-7 526PD
Old 10-07-2019, 09:18 AM
Mark33's Avatar
Mark33 Mark33 is offline
I’m purposefully installing them on my -7 taildragger project for this exact reason. The two modifications that I did was to shorten them by 4” and I’m making them removable. If/when I remove them I’ll just have little cover plates held on by four screws each to cover the holes.
If you decide to install them on your -8, I’d definitely take some measurements and shorten them as needed, but I suspect you’ll need to shorten them by about 4” as I did on my -7, because on a taildragger the stock length of the steps will put them too low to the ground. You basically want to make the length of the steps to be so that it’s a “natural stride”...or as close to a natural stride as possible, that your step from the ground to the step and then from the step to wing as close as possible.
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
Old 10-07-2019, 09:46 AM
DennisRhodes DennisRhodes is offline
I installed them on a 9 which was converted from a 9A airframe. Use them every time i get in not so much in getting out. But they are very handy in making that first step up onto the wing especially as things get older! The steps were the ones furnished for the 9A kit, I did not shorten or look for different ones. Operate the 9 off a grass strip and will ocassionally pull grass off the step
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 10-07-2019, 10:20 AM
fl-mike's Avatar
fl-mike fl-mike is offline
yes.
Installing one on my 8. I shortened it a bit.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 10-07-2019, 12:06 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Steps are a good idea. For passengers I carry a small folding step stool....
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 10-07-2019, 01:06 PM
mfleming's Avatar
mfleming mfleming is offline
If you do decide to install them and want to shorten them, McCutcheon Metal Fabrication makes them for Van's and will do a superb job of shortening them for a small fee.
On my -7 I shortened them 3" but 4" would also have worked.
You can contact McCutcheon Metal Fabrication on Facebook...
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated for 2019 and so should you
Old 10-07-2019, 01:26 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Steps
I converted my 9a build to a 9. Kept the steps the standard size and would not change them and happy to have them.
Al Girard, Newport, RI
N339AG
RV-9
Old 10-07-2019, 01:39 PM
Hornet2008 Hornet2008 is offline
I have steps on my 9 and glad I did it.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 10-07-2019, 01:53 PM
Mark33's Avatar
Yes, thatís exactly what I did. He charged me $100 to do the work.
Regarding how much to shorten the steps, I took the measurement straight down from the center point of where the step enters the fuselage down to the ground. I then put the step in position and measured from where you put your foot on the step, to the ground.
I then laid a straight edge on the wing going aft.... simulating the trailing edge of the wing continuing aft. Then I just split the difference in the measurements.
Basically, I wanted it to be the same natural step distance from the ground, to the step, then to the wing. Thatís how I came up with the 4Ē that needed to be removed.
Mark H.
RV-7- (Building)
