  #1771
Old 08-07-2017, 09:11 PM
Simon Hitchen Simon Hitchen is offline
Default From concept to reality
After a lot of ideas and modifications and colours (red then silver then yellow then finally blue...) we finally agreed on the scheme below. I stuck with it and am happy that it worked out ok. Weigh in is tomorrow...
Seems the work load is increasing rather than decreasing!!
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 08-08-2017, 09:14 AM
jMINTj jMINTj is offline
Simon, nice progress and paint! Good luck with the inspection. Looking forward to seeing the first flight!
v/r,
-MINT
RV-7A
https://jmintjrv7a.wordpress.com/
EMPENNAGE
VS Complete
Rudder & HS - In Progress!
Old 08-08-2017, 02:04 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Pretty
Nice Paint job....
Shop / hangar is sweet too.
Beautiful guard dog....
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 09-30-2017, 08:51 AM
Default Apparently airworthy!
On Sept 18th C-FCSH was inspected by not one, but two Canadian MD-RA inspectors (one inspector and one trainee inspector).
All went very well, the inspection itself took around three hours with only two snags found. One "less than tight" jam-nut on an aileron pushrod and one cotter pin touching a brake line.
Paper work took another few hours to complete but the day ended well with the promise of a Special Certificate of airworthiness to arrive in the mail in a few weeks. Long day for sure.
A week later I called the MD-RA regional boss and he emailed me the certificate immediately. Impressive service really.
So apparently I'm good to go! I've got a few more things to tidy up before the big day and our airport is currently closed for runway resurfacing until Oct 10th, so no rush. Can't quite believe Im legal, insured, registered and certified to fly this long term project!
Many Thanks to my wife Clare and kids Lauren and Dean for being endlessly patient, especially since the aircraft was moved to the airport a few months ago and to John Van Lieshout for a thorough pre-inspection inspection. To the countless friends along the way that've pitched in with helping hands, to Marty and John my MD-RA inspectors who made the day enjoyable with good banter throughout and to Jamie Alexandre who completed the paperwork in record time.
Exciting times!
Simon Hitchen
FLYING!
Old 09-30-2017, 11:27 AM
Ryano Ryano is offline
A proterozoic (and somewhat special) RV-7 hatches from it's egg casing!
Practice Kit completed 2/19/2017
Tooling up for -7 empennage build.(99.8% tooled 9/16/2017)
Orphaned -7 empennage kit purchased! 9/15/2017
2017 Donation paid...
Old 01-15-2018, 04:03 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Finished horizontal intake.
Started and finished trimming baffles over this past weekend. I have a nice evenly spaced (3/8"ish) baffle to cowl. Still need to do the air gap seal.
Also started the install of the baffle mounted SW8432R oil cooler. Made new wider and thicker support plate out of 6061-T6 for bigger cooler. Still need to get corner angle made for additional support.
https://www.youtube.com/watch?v=mdbwRKeEohc
Carlos in Arizona
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 01-15-2018, 08:33 PM
you may consider opening the clearance of the oil cooler flange to the engine mount rod. the oil cooler will move with the engine about an inch up and down at the outermost edges during startup and shutdown. it's the tail wagging the dog scenario.
Old 01-15-2018, 08:46 PM
You are correct and this is initial fitting to see if it would work at all. Still have clearances I need to address with the flange. That opening will widen of course so there's no contact on start/shutdown between the cooler flange and motor mount brace.
Carlos in Arizona
