Old 05-14-2019, 05:52 PM
azflyer21 azflyer21 is offline
Default Tablet mount - Show your setup - RV14A
Curious how you have mounted a tablet in your RV14?
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 05-14-2019, 08:39 PM
bkervaski's Avatar
bkervaski bkervaski is online now
I haven't found a tablet necessary with the Garmin G3X Touch and GTN combo. What avionics are you planning?
Progress: Flying!
Old 05-14-2019, 08:53 PM
rwthompson67's Avatar
rwthompson67 rwthompson67 is offline
I used to fly an RV-8A with a single Dynon D-180 and some steam gauges. I considered my Ram mounted iPad running ForeFlight (coupled with a Stratus) required equipment.
Last week I flew my RV-14 (dual HDX and a GTN) from Oregon to Virginia. We had an iPad loaded with ForeFlight in the cockpit but never felt a need to fire it up.
________________________________
Rick Thompson
RV-8A N306R #82456 Bought/Sold
RV-14 N327RT #140347 Built/Flying
TBolt IO-390, Dual PMAGS, Hartzell composite, Dual HDX
Phase 1 Complete 4/17/2019
Old 05-14-2019, 09:03 PM
Dual HDX and IFD440.
Kevin Lippert
Sold
N1402 reserved
Build Log
Old 05-14-2019, 09:07 PM
That's good to know, looks like I'll be good without a tablet in the cockpit. How long was your flight time from Oregon to VA? My engine and panel will be just like yours except for the GTN, I'm going with the Avidyne IFD440.
Kevin Lippert
Sold
N1402 reserved
Build Log
Old 05-15-2019, 01:05 AM
mturnerb mturnerb is offline
I'm finding the same thing. Use tablet or phone to upload flight plan. Then never look at it again.
Turner Billingsley
RV-14A FLYING!!
Old 05-15-2019, 09:03 AM
n982sx n982sx is offline
With a dual screen EFIS I would agree that loading the flight plan is all you need the iPad for. It becomes redundant in the cockpit.
However, for any single screen builders out there, my setup with an iPad works well. I have a single screen G3x touch, 625 and a G5. I use a powered mount for my iPad as a second screen. It is easily removable in flight and I can put it on my left knee with Sportys cheap but effective iPad knee board.
I use it to review weather or make changes to the route in flight. It was very handy coming back from Sun-n-Fun this year for those very reasons. Worked very well and saves on a second screen.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 05-15-2019, 01:27 PM
Jake14 Jake14 is offline
I agree that with 2 screens on the panel an iPad would be redundant. I have just one AFS5500 and an iPad mini velcroed to a RAM ball mount (see pic) just above my left knee. It has FlyQ connected to a stratux for traffic or geo-referenced plates and can also display a backup AI. I find I use it about half the time. The mounting is close and gives good screen visibility with the adjustable angle and is convenient for poking the screen. Also gives cheap, independent EFIS redundancy with over an hour battery life just in case...what's not to like? :-)
RV-14A #140158 flying
Old 05-15-2019, 04:39 PM
Boyd Birchler Boyd Birchler is offline
I have 2 G3X screens and a standby dynon 10A.
I mount a full size Ipad on a RAM mount to the far right. The RAM ball is permanently attached to the panel.
My reasoning is if everything else fails the Ipad will give position and map for a few hours on its internal batteries...
Old 05-16-2019, 12:55 AM
Erimo's Avatar
Erimo Erimo is offline
The same cockpit !
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
