Old 04-15-2019, 04:15 PM
Mickrat Mickrat is offline
Default Leading Edge Check
Hello all,
This is my first post, been reading this site for months though.
Iíve recently started an RV-14A empennage kit. I wanted to check with you regarding the bend on my rudder leading edge.
Thanks.
Old 04-15-2019, 04:18 PM
Auburntsts's Avatar
Itís fine. Youíll never see it once itís mounted to the VS.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-15-2019, 04:19 PM
bkervaski's Avatar
bkervaski bkervaski is online now
The goal here is to make sure the skin doesn't pull on the part underneath and develop a stress point. You want it to go out a bit and then start the curve. It took me more than a few attempts to get it just right.
What are you using to do the "roll"?
Progress: Flying!
Old 04-15-2019, 04:22 PM
Default Welcome to VAF, and Congratulations
Originally Posted by Mickrat View Post
Hello all,
Mick, welcome aboard the good ship VAF-----congrats on the build
Old 04-15-2019, 04:54 PM
I used this 3/4” EMT. Drilled a 1/4” hole in the end for my screwdriver. It seems if I had a smaller radius I wouldn’t have enough material to reach the other edge.
Old 04-15-2019, 04:56 PM
DeltaRomeo's Avatar
DeltaRomeo DeltaRomeo is online now
Your host.
Mick, mine didn't look that good.
Welcome aboard Sir.
v/r,dr
doug reeves.
- Biz card: www.DeltaRomeo.com
Organ donor card signed (use anything you need).
RV-6 flying since '02.
- Commercial Rating (2019 - in the RV!)
- IFR Rating (2015 - in the RV!)
Old 04-15-2019, 05:14 PM
May I suggest you get someone to look over your rivets before going too much farther.
Couple of these are not looking too good, not sure if this is a camera induce issue or not.
Old 04-15-2019, 05:37 PM
Girraf Girraf is offline
Agreed. Easier to fix them now.
RV-7:
Empennage complete!
Wings in progress
Old 04-15-2019, 05:43 PM
They don’t look great from that top view. Do they look better in the first picture?
Old 04-15-2019, 05:57 PM
Auburntsts's Avatar
Not really. The center vertical row of rivets that are in line with the hole all looked clinched, especially the top 2. That typically happens with a rivet thatís too long for the material thickness, but can happen for other reasons such as a misaligned bucking bar. A lot of the others look under-set but pics can be deceiving. Do you have a rivet gauge?
Todd Stovall
PP ASEL-IA
WAR EAGLE!
