Old 02-10-2019, 05:49 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by N941WR View Post
Think about which hand will operate each switch and what phase of flight you will operate it. Then place the switches accordingly.
As Rob did, starting switches are on the right because he will move the throttle with his left hand.
Putting the SkyView as high as you can is great advice! If you can do this, put the nav stuff on the left and the SkyView control boxes under the EFIS with the knops on the left side and the AP box on the right.
Fuel pump, landing, taxi lights, etc on the left.
Something like this perhaps..
(one of my favorites that we did for a customer)
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-10-2019, 10:12 AM
N402RH's Avatar
N402RH N402RH is offline
Here are some more IFR RV-8 panels that we have done, the second one is in Andy Manilas 2018 Bronze Lindy award winning RV-8.
How about a 12" EFIS in a RV-8:
We have done a lot of these RV-8 panels
Rob Hickman
Advanced Flight Systems
N402RH RV-10
Old 02-10-2019, 05:39 PM
ksdflying ksdflying is offline
Why do you need two PFD's. You have the 430. Thats 3 moving maps. Thats 1 too many. Waste of money.
All you need is one nice PFD screen, and 650 rather. I wouldn't do the 430W. Its old technology. But that is just me. I certainly wouldn't waste money on excessive and repeat glass panels. No need for that. Assuming you want legal IFR capability, but still, Simple is Better.
Dan K. RV-8 kit purchased 2014, build start Jan 2018, Slow build Emp. done - March 2018, Slow build Wings done -Oct 2018, QB Fuselage started - Sep 2018
Avionics in - April 2019. Engine and Finish kit in hand 2019.
VAF dues paid!
Old 02-10-2019, 05:40 PM
And I second Walts suggestion. Spot on correct.
VAF dues paid!
Old 02-10-2019, 08:47 PM
LuckyDuck LuckyDuck is offline
I can tell you that the Advanced Quick Panel picture #1 is a true joy to fly with. Having the ADI in the PFD centered in front of me makes for an easy instrument scan. All of the components work together flawlessly and are easy to reach and work with. I'm obviously a bit biased but after flying with it for over a year, I would not change a thing.
Old 02-11-2019, 02:43 AM
SuperCubDriver SuperCubDriver is offline
I also suggest to put the PFD as high as possible.
Im having two 7" screens one on top the other. While the upper screen is easy to see and read, the lower is not so. For me its ok as backup or map display but the position is not perfect. Some time during cruise I have the upper screen configured as map display for better readability.
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
Old 02-11-2019, 05:48 AM
sailvi767 sailvi767 is offline
Just a thought but I would consider a 650 to replace the 430. I realize its a cost but I wonder how much longer the 430 will be supported. Hopefully for a long time as there are a large number out there but in 5 years who knows.
G
Old 02-11-2019, 06:38 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
There's advantages to having radios on the right, especially if they require lots of switchology like a GPS.
Double check the readability of smaller screens. I'd give serious consideration to one big screen over two small screens. And the RV-8 is a great sport plane (I have one) but I don't think I'd want to fly it IFR....
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 02-11-2019, 10:31 AM
N804RV's Avatar
N804RV N804RV is offline
Ed
Ed, this really puzzles me. I currently fly a little Sonerai with nothing more than a handheld radio. Because of layout of the cockpit, the only place I can put the handheld is on the right side. That is, without bolting some kind of mount somewhere that would inevitably end up being a big snag for clothing and possibly further complicate ingress/egress.
So, I'm constantly switching hands on the stick to fiddle with the radio. I've had 2 different plug-in PTT switches, both failed very quickly. And, I finally quit messing with them. I planned on having the radios and knob panel on the left side in my RV-8 so I could keep the right hand on the stick.
After all this, I am seriously considering going with one 10" Dynon screen with their radio and ICS. And, maybe a D-10A as a back up.
Look at that, you guys may have just saved me at least $8K on my build!
Ken W.
Mount Vernon, WA
2019 VAF Supporter
Old 02-11-2019, 10:36 AM
N402RH's Avatar
Originally Posted by N804RV View Post
How much clearance is there between the IFD 440 and the F-802T-1 LG tower upper aft brace?
Yes, it clears.
Rob Hickman
N402RH RV-10
