Old 12-05-2018, 04:12 PM
SPX SPX is offline
Default Routinely using an RV-6A for a 420 NM trip
I am considering purchasing an RV-6A for a 420 NM trip, each way, about 3x per month. Id fly it day VFR only.
Can I get some feedback/opinions as to the suitability of the airplane for this type of trip? Im 510, 180 LBS, AND 32 inseam. How about comfort for the roughly 3 hours aloft that this trip would take? How much storage space for a suitcase will I find in an RV-6A?
Any RV-6A owners in SoCal that might be willing to talk to me, or take me up for a ride in theirs? Also Id be up for any leads on aircraft that you may know of that would fit what Im looking for.
Many thanks!
Old 12-05-2018, 04:27 PM
DeltaRomeo's Avatar
Your host.
Autopilot = yes? Easy trip in a 6A.
You and I are roughly the same weight (me 168lbs). Exact same height (5'10"). I fly an RV-6 1.5 hrs down to Houston from DFW to see my sister every so often. Painless down and back.
Taking out the passenger seat back will give you all the baggage room you would ever want.
The toughest part IMHO will be finding VFR on all your trips out near San Diego.
Welcome aboard the Good Ship VAF as Mike S. says, and good luck with your search. If you're every in DFW look me up - we'll go fly the -6.
v/r,dr
doug reeves.
Organ donor card signed (use anything you need).
RV-6 flying since '02.
- Commercial Rating (2019 - in the RV!)
- IFR Rating (2015 - in the RV!)
Old 12-05-2018, 04:35 PM
Jonathan Alvord Jonathan Alvord is offline
Should be a breeze. I have been doing 750mile trips from AZ to Wa since May/June. not necessarily 3 times a week but the RV 7A is perfect for it. Recommend an autopilot! Beats driving!
N122EF RV7A
S40 Prosser Washington
=VAF Dues paid 2018=
Old 12-05-2018, 05:53 PM
N941WR's Avatar
N941WR N941WR is offline
I commuted from Greenville, SC to Pearland, TX 720 Nautical miles each way every other week. The RV works great for such trips!
I miss that Texas gang, great bunch of people!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-05-2018, 06:06 PM
That's a great 2.5 - 3 hour trip in a -6.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-05-2018, 06:20 PM
Boyd Birchler Boyd Birchler is offline
I'm 70 pounds heavier and an inch taller. Wife and I swap out legs. We just flew a 10,700 NM trip in our 7 earlier this summer (perimeter of lower 48 states).
For all intents, the 7 cockpit is the same size as the 6 (It has lower seat pans but we need 4 1/2" rigid foam under the existing seat cushions in order to see over the nose, so in our case the extra seat pan depth is of no value).
Some builders with hanging peddles moved them closer to the pilot, a few moved them further away. In any event that can be changed if needed.
Autopilots are so cheap now days (used) that they are a must have item on long XC's. Also on my list is a CS prop and gear leg dampeners...
Old 12-05-2018, 06:23 PM
sahrens's Avatar
sahrens sahrens is offline
I just flew from Garden City KS to N California via Gallup NM and Lancaster CA in one day in a RV-7. Different model but almost the same size. While I was tired at the end of the day I wasnt ever uncomfortable. Good seat cushions are the key.
Good luck with your search, you will love your RV.
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 12-05-2018, 06:29 PM
gmohr gmohr is offline
We fly our 6A from S17 to KBHM routinely and it is easy. I am 5'10" 180lbs.
We can pack enough clothes for a week and still have room for the dog carrier.
Gene Mohr
Ret. US Army, SP-ASEL, PP-ASEL
RV6A (purchased), O360, Hartzell C/S prop
Trenton, SC (S17 homebase)
Happily Donated
Old 12-05-2018, 07:04 PM
SPX SPX is offline
Thank you for the great replies.
Is it safe to say that I should see 150+ KTAS on ~9 GPH?
Old 12-05-2018, 07:10 PM
Billythekid Billythekid is offline
Default rv6 fit
there is a rv6a at ksdm that has a few folks watching over its care.. if you go down to eaa ch14 and ask around you might get a opportunity to sit in it and see how things fit. pm me and I may be able to arrange something. just trying to be on the square and level... billythekid
