Old 12-05-2018, 06:59 AM
romanov's Avatar
romanov romanov is offline
Question Question: maximum trimmer angle move
Hi Guys,
I didn't find any info in the specs so will ask you
expirienced fellows: is that trimmer move looks
good to you?
Does anybody has an info about
the angle the trimmer should go?
Thanks in advance
Roman
Blogging my RV14 here:
https://bit.ly/2PzjPzS
Old 12-05-2018, 10:45 AM
romanov's Avatar
Measured the angle of the trimmer:
35 degrees down
10 degrees up
does it make sense to have such a difference?
Old 12-05-2018, 10:52 AM
Default yes
As the limited "up" throw actually will trim the elevator "down" yielding Aircraft Nose Down.
The increased "down" throw, trims the elevator "up" yielding Aircraft Nose Up.
You will need FAR more Aircraft Nose Up trim than down, so yes, it does make sense...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 12-05-2018, 10:57 AM
romanov's Avatar
As far as I can see now the diff between up and down in elevators
is 5 degrees, down is about 25 and up is 30 , so given that all,
it still leaves me with the question: why in the trimmer move the
diff is much more dramatic?
Old 12-05-2018, 11:30 AM
Nova RV Nova RV is offline
Here is your answer from Vans maximum 13/35 up/down minimum 11/32 up/down:
https://www.vansaircraft.com/pdf/let...ons_Letter.pdf
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 12-05-2018, 11:32 AM
romanov's Avatar
Thanks a lot. Where did you find that one?
Old 12-05-2018, 11:40 AM
It's on the Vans website under support for the 14.
Remember too that up refers to the direction of the trim tab, not the resulting trim direction of the elevator. Up trim tab = down elevator movement in flight. So you want 13 degrees up trim tab max = max down elevator trim and 35 degrees down trim tab max = max up elevator trim.
Shoot for the max values especially on the trim tab down movement as you need up elevator trim quite noticeably with flaps and to flare for landing.
Chris Moon
Leesburg, VA
Old 12-05-2018, 01:37 PM
romanov's Avatar
Yeah, I do understand that, but yet the elevators angle
difference is not very big, is it cause eventually it is
achieved by very small angle of elevator?
Old 12-06-2018, 04:26 AM
rzbill's Avatar
rzbill rzbill is offline
Think about the flight regimes in play when using the trim tab and you will have your answers. How fast are you going when nose up trim is needed? Is there a nose down moment created by a configuration change? When do you need nose down trim? How fast are you going at that time? Do you need a LOT of elevator movement for that condition?
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 12-06-2018, 08:46 AM
There is no direct connection between how many degrees of travel the elev. the elevators have up and down from neutral, and how much travel the trim tabs have up and down from neutral.
The elevators travel range is based on how much travel the pilot needs for all flight conditions, to control the aircraft.
Example - enough nose down elevator for stall recovery, etc.
The trim tab travel is based on how much travel is required to attain hands off trim in any normal flight condition.
Example - pitch trim will never be used to recover from a stall so the trim tab doesn't need to have enough trimming authority to induce full down elevator.
A general rough guide line on all of the RV's (except the 10 and the 12), the trim system should be adjusted so that the trim tab will proved about twice as much nose up trim (tab travel down) as it does nose down trim.
If the parts supplied with the RV-14 kit are installed per the plans, this is approx what the travel ratio will be, and in flight the pitch trim will provide sufficient trim authority for all modes of flight.
Scott McDaniels
Hubbard, Oregon
