Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 11-08-2018, 07:03 AM
marked marked is offline
Default Moving a plane into a Mode C Veil, cheapest solution for Transponder and ADS-B
I'm buying my first plane and I have found a plane I like, but it is located in an area where it has never needed a transponder. Full disclosure it is experimental, but not an RV. I am just posting here because 90% of the valuable information Google finds me on experimentals (especially avionics) is from this forum.
My question is, if I do the install, what is the cheapest solution for a transponder and ADS-B on a plane that never had either?
Old 11-08-2018, 07:06 AM
bkervaski's Avatar
bkervaski bkervaski is online now
Congrats on your purchase! Pics?
Be cautious of going "cheap".
There's a lot of spin ups trying to take advantage of the ADS-B deadline creating a lot of competition. A lot of these companies will go out of business or stop selling their ADS-B solution because all the competition will make it impossible for some to profit.
It's already happened to a few, search for "NAVWORX".
You don't want to find yourself buying another transponder, buying two is certainly not the cheapest solution.
Progress: Flying!
Old 11-08-2018, 07:26 AM
Mel's Avatar
Mel Mel is offline
I agree with bkervaski. Cheap is not always economical. Do your research.
I went with Trig. I've had Trig in 2 airplanes over quite a few years and very happy with their system.
Complete ADS-B out including TT22 (Mode S transponder), TN72 (ADS-B compliant GPS), and TA70 (GPS antenna). All for about $2400.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 11-08-2018, 07:36 AM
Generally, I am but I am looking at a sub $15k plane, and I don't want to put $5k in avionics in it just to be able to fly.
Not having to do this twice is exactly why I am asking, part of me wants to just install a $250 used transponder and encoder to last a year, and then add a UAT next year. But I want to know that there are not better options. You RV guys tend to find the best mix of budget and quality that I have seen, so I presumed that this has been discussed a bit. I did find some good information in searches but some references to the Trig T22 (which I had not heard about) in a thread about the echoUAT lead me to create my own thread. I want to make sure that I haven't overlooked an option because I don't know what to ask.
Old 11-08-2018, 07:54 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
In the long run "Cheap" will wind up being very expensive. That being said, your best option will depend on what you currently have installed in your panel and what your eventual "mission" will be with the airplane. IOW more information is needed before options can be discussed but it sounds like you will require a transponder at the bare minimum.
Something like this transponder with ADS-B OUT and built in GPS.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
Old 11-08-2018, 07:56 AM
10builder's Avatar
10builder 10builder is offline
Default Economical vs. Cheap
Without knowing the rest of your panel setup it's challenging to present all of the numerous options, and thinking short term rather than what you want your panel to look like in 5 years could end up costing you more. FWIW, I'm going simple VFR (Mini-X) and chose to control a remote Sandia transponder (STX-165R) and using the uAvionix Echo UAT/GRT Safe-fly GPS package. My goal was a simple, uncluttered panel - but your goal may be totally different.
Brian S.
Arrington, TN
SPA Panther N87XP
RV-10 N104BS (Sold)
2019 VAF donation cheerfully submitted!
Old 11-08-2018, 08:07 AM
rocketbob's Avatar
rocketbob rocketbob is offline
In my opinion the Trig TT22 ADS-B bundle is the best, least costly 1090ES option.
I've done a few 978-out installs and find traffic with those devices spotty at low altitude, well away from a ground station. I've seen too many mode-C targets fly right past me and nothing show on ADS-B, but an old Zaon picks it up.
1090ES does not have this issue since its an extended squitter mode-S transmission so dual-band ADSB receivers will pick up the traffic, without relying on a rebroadcast from a ground station. Assuming the traffic near you is also 1090ES. At least maybe they'd see you and you not see them, if properly equipped.
You can get ADS-B in with an inexpensive receiver, such as a Stratux, which also gets you a perfectly usable backup AHRS to display attitude on an iPad.
If you can accept the drawbacks of UAT and are ok with spotty traffic due to drawbacks of the system design, then you go with a cheap used transponder now and add a uAvionix EchoUAT, and also get ADSB-IN traffic/wx and not have to get an external IN box.
The other option is a cheap transponder then add a GDL-82. I consider the GDL-82 simply as a compliance box.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 11-08-2018, 08:11 AM
RV6_flyer's Avatar
Others have mentioned the Trig and I agree it is a good value.
I am planning on using the Appareo-Stratus as I feel it is the BEST for my RV-6. Everything in ONE box. Easier for me to retrofit into a flying airplane. I will either buy from Stein or RST sometime in the next few months.
I plan to abandon my Grey Code encoder and use the serial port from my Garmin G5 as my altitude source.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-08-2018, 08:14 AM
Mike S Mike S is online now
Default Welcome to VAF, and Congratulations
Mark, welcome aboard the good ship VAF
Congrats on the plane-----enjoy it.
Old 11-08-2018, 08:32 AM
Toobuilder's Avatar
I understand that using 1090ES (vs UAT) takes the "anonymous" option off the table. That's a consideration for some of us.
Michael Robinson
______________
RV-8 - Flying
