Old 10-08-2018, 01:05 PM
Av8torTom's Avatar
Default Garmin GDU 460
Has anyone installed a Garmin GDU 460 (10+" display) in a 9A panel?
Seems awfully tight. Anyone have pics?
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, engine hung, working on panel and wiring)
N677AT reserved
Superior XP O-320, 160HP
Old 10-08-2018, 01:18 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Default GDU460 in RV-9A panel
Like this one?
http://4.bp.blogspot.com/--TQquY8jZn...2B08.52.04.jpg
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Finishing Kit
www.DarinAnderson.com
2019 donation sent!
Old 10-08-2018, 01:24 PM
Walt's Avatar
Walt Walt is offline
Currently have an RV9 panel update in work, RV9 with dual 460's and GTN750.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-08-2018, 01:25 PM
Av8torTom's Avatar
Originally Posted by Zuldarin View Post
I see you added an extension to the bottom of your panel.
Could you have made it fit without that, and put the switches where you wanted?
N677AT reserved
Old 10-08-2018, 01:26 PM
Av8torTom's Avatar
Could you share where you plan to position on the panel?
N677AT reserved
Old 10-08-2018, 02:56 PM
Zuldarin's Avatar
Yes, there is plenty of room for switches. I will say that my panel is not the stock van's panel, its the modular panel from Affordable panels and that is where the switch extension comes from. Still there is plenty of room but you do need to be cognizant of the support rib behind the panel
Darin
Snoqualmie WA
2019 donation sent!
Old 10-08-2018, 03:10 PM
Walt's Avatar
Basically the same as this 7 I did but with a GTN, audio panel and auto pilot panel in the center stack. The 9 is also a slider not a tip up.
Old 10-08-2018, 03:44 PM
Av8torTom's Avatar
Walt, can you tell me the size of the opening needed for the EFIS?
N677AT reserved
Old 10-08-2018, 04:22 PM
Walt's Avatar
Exact dimensions are available in the G3X install manual which you can download from the G3X website.
