Old 10-05-2018, 07:22 PM
N941WR's Avatar
N941WR N941WR is offline
Many of the ELT's are designed to be removed from the plane and used with a removable antenna.
The problem is that many builders mount them behind a bulkhead and they aren't accessable unless you have a power screwdriver to remove a bunch of screws.
I mounted mine to a rib under the baggage compartment floor and used big screw knobs that I can remove with one hand, if the other hand is injured.
(Click to enlarge)
The telescoping ELT antenna was mounted on the right side flap cover, held in place with an adel clamp and positioned so it is touching the aft spar bulkhead. My hope is that in the event of an accident, it won't slide forward and get damaged.
(Click to enlarge)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-06-2018, 10:32 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Or just a regular old hand screwdriver in your emergency kit.
2019 Dues paid!
Old 10-07-2018, 07:37 AM
N941WR's Avatar
That kit can become a projectile or you may not have the time to remove all the screws due to fire risk or you might have broken ribs that make using a screwdriver in an upside-down fuselage nearly impossible.
Bill R.
SC86 - Easley, SC
Old 10-07-2018, 02:51 PM
RV7A Flyer's Avatar
Which is why I have a PLB attached to my harness.
*Anything* can become a projectile if not properly secured.
2019 Dues paid!
